What mounting kit are you using?
The way mine is setup, and just set up another setup the same, requires cutting and welding of the tunnel/firewall....... This way uses a custom mounts to mount to a std 4a crossmember to retain close to standard steering geometry...
You may need to also drop the X member to make it easier to get the box/engine in as one..
