Results 1 to 4 of 4
Thread: Silvertop 4AGE's and oil coolers
    Juston
    Default Silvertop 4AGE's and oil coolers
    What's the best way of setting up an oil cooler on the 20 valves? My track car with a freshly rebuilt engine was hitting 110 degrees whilst on track and 120 after I eased off before it cooled down which I thought was too high.
    I've read that the sandwich plate off a smallport bolts on but doesn't have a thermostat but haven't verified it. I also would like to avoid having to relocate the oil filter if possible as I want to keep it simple.
    I've also heard of people running oil coolers having issues with the vvt as it affects oil pressure, but it seems to be more of a blacktop issue.
    Any advice would be greatly appreciated.
    Noooob
    I've never ran an oil cooler on any of my 20vs... But smallport oil sandwich plate is the way to do it with a drain back to the sump, otherwise aftermarket cooler / relocation kit
    Member rianwest's Avatar
    May 2010
    Rian
    Taringa
    16 valve sandwich plates don't use a thermostat, but they do use a pressure release valve that opens at a certain pressure to allow oil to pass through the oil cooler.
    But keep in mind you need an oil return in the sump to run this setup.
    I'd go with an aftermarket sandwich plate that has a thermostat, where both the feed and return for the oil cooler come from/go into the sandwich plate. Like this Mocal unit:
    Juston
    Thanks rianwest. That's exactly what I'm after.
    Where is the best place to buy one of these sandwich plates? I don't want to buy some Chinese rubbish that's gonna cost me an engine when it fails.
  1. Replies: 6
    Last Post: 2nd May 2013, 12:35 AM
  2. oil coolers on N/A 4age worth it??
    By shift_rook in forum Technical - Questions
    Last Post: 9th February 2009, 08:40 PM
  3. oil coolers
    By slippry in forum Technical - Questions
    Last Post: 25th September 2008, 05:39 PM
  4. Oil coolers
    By eightsixboy in forum Technical - Questions
    Last Post: 19th October 2007, 02:35 PM
  5. oil coolers
    By D0R186 in forum Toyotas in the Media
    Last Post: 13th July 2007, 01:51 PM
