Results 1 to 3 of 3
Thread: Tokico hts102r stuck adjustment
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    Default Tokico hts102r stuck adjustment
    Hey all I've come across a pair of tokico hts102r for the rear of my ae86 but one of them seems to be stuck on super hard adjustment. Even with the grub screw wound out.
    I've read bits n pieces about not winding the screw all the way out but with the 102s you wind the screw in for harder. So it's like the valve is stuck in.
    Atm you can't even pull the shock for rebound even with two ppl so they will be far to hard for use
    if anyone has any tips for freeing up the valve please do tell
    craig
    Veteran shift_rook's Avatar
    SE Burbs
    Even on full hard you should be able to pull it up to full extension. If the damper isn't fully compressed try pushing it to full bump, if it's gettign stuck at a certain point i would dare say they're stuffed.
    Sep 2010
    Craig
    Perth hills
    On the other one with the adj wound all the way to hard it only just is able to be pulled. But then u can wind it all the way to where it very easily extends again. This is the same as that one but when u wind it to soft it just stays at the same hard point as the other. It does extend but VERY slowly. Once it's all back to full ext u can compress it again at the same rate that the other one does
  • Similar Threads
    1. tokico hts102r
      By Rice86 in forum Technical - Questions
      Last Post: 22nd November 2012, 10:19 AM
    2. Tokico HTS102r 48way adjustable rear shocks
      By patience in forum Car Parts For Sale
      Last Post: 27th June 2010, 05:08 PM
    3. Tokico HTS102r adjustable rear shocks
      By duncan_86 in forum Car Parts For Sale
      Last Post: 13th November 2009, 04:08 PM
    4. Tokico HTS102r + other stuff
      By kaibeecee in forum Car Parts For Sale
      Last Post: 18th June 2009, 11:16 AM
    5. Tokico HTS102r rear shocks.
      By DRFTAE86 in forum Car Parts For Sale
      Last Post: 14th May 2008, 12:12 AM
