Results 1 to 10 of 12
Thread: 1sz solid lifter
    Member 96sonataBro's Avatar
    Mar 2012
    Hugo
    W.A.
    s.o.r
    Default 1sz solid lifter
    Hey all, I'm about to do the 1sz solid lifter upgrade and was just wandering if you have to change the keepers swell or can you just USSR standard/supertech keepers ? Cheers
    May 2012
    ACT
    belconnen
    Well, your not changing your retainers, or your valves. so no, the standard keepers still work.
    Mar 2012
    Hugo
    W.A.
    s.o.r
    Sorry about the English above I was in a rush at work. I am putting a big cam in so I will be going with supertech duel valve springs and retainers, I just assumed that they where the same basic design just stronger. I just want to be 200% sure they are compatible before I fork out
  • #4
    Veteran timbo's Avatar
    Tim?
    Wild West
    What is the cam lift? Dual valve springs, is it a 18RG?
  • #5
    May 2012
    ACT
    belconnen
    Quote Originally Posted by 96sonataBro View Post
    Oh right. Well, the keepers hold themselves into the retainer by their taper. The bore size on the retainers shouldn't be different, which would mean they would work with standard keepers. If they are different and don't fit, you should still be able to use the standard retainers with the supertech valve springs.
  • #6
    Mar 2012
    Hugo
    W.A.
    s.o.r
    Quote Originally Posted by timbo View Post
    cam lift is 10.50/10.25, not sure what 18rg is. these are the springs
    >http://www.ebay.com.au/itm/Supertech...item2a26daa910
    SamsTA22 i meant to say retainer in the first post although i will probably be using the supertech keepers with the springs and retainers. Here is a link to the thread where i read something about changing the spring retainer to suit the bucket but i can seem to find any more info, if someone could clarify this for me it would be much appreciated
    >http://www.rollaclub.com/board/topic...et-conversion/
  • #7
    Jun 2011
    james
    oxford
    general area
    England
    The valve adjustment is done by the thickness of the top of the followers so you will need to measure each of your current followers / shims with the cams you want to use so you can buy the correct size followers.
    It is worth checking you can actually get the sizes you need before you commit.
  • #8
    Veteran Skylar's Avatar
    Ken
    You can always juggle the lifters around and grind the tip of the valve if you have the wrong thickness lifter. My engine builder has a bunch of shims that I swap with when I don't have the right one. Maybe your engine guy has a similar scheme?
  • #9
    May 2012
    ACT
    belconnen
    I'm guessing you're referring to the last post on that thread?
    The 1sz lifters don't have removable shims. That's why you have a different part number for each size. Besides, the retainers don't hold the shim in; the shim (if you can even call it that) pushes against the valve stem.
  • #10
    Senior Member Prime86's Avatar
    Sep 2009
    Brad
    Perth hills
    If you go with the 1suz lifter upgrade you don't need to change your retainers, just use the standard ones there fine. I had the 1suz conversion in a small port head with big cams. You buy the lifters in the sizes you need as there shim less, no grinding or anything required just but the size you need. It wasn't a cheap conversion as the tappets are pretty pricey when you add it all up. I've since removed the tappets from my head and just have them sitting around, I have a heap of them new in bags and second hand ones also, hit me up if your interested or just want to see what they look like.
  • Page 1 of 2 1 2 LastLast
    1. solid lifter upgrade 16v 4age.
      By MoNsTaR in forum Technical - Questions
      Last Post: 19th February 2014, 07:41 PM
    2. 4AGE lifter size
      By driftnick13 in forum Technical - Questions
      Last Post: 20th September 2009, 10:23 PM
    3. fuel pump + lifter
      By todd in forum Cars or Parts Wanted
      Last Post: 9th March 2009, 11:49 PM
    4. surge tank and lifter pump
      By connection in forum Cars or Parts Wanted
      Last Post: 23rd July 2008, 02:05 PM
    5. VL LIFTER PUMP
      By Gullie in forum Car Parts For Sale
      Last Post: 11th May 2008, 02:09 AM
