I mean how much hp have at 14.7 psi or a other pressure.
Here is my datasheet from my dynamometer run.
ECU is a Microtech
315 at the wheels. There is a scan of my dyno chart on the top sticky thread in tech questions.
Turbo is a hks gt2540
My motor has a static compression of 9.08:1 so I am limited to a maximum if 24psi. Any more than this and there is an exponential risk of lifting the head off the block
Don't understand the last question.
The only other time I had it dynoed was for run in. On 7psi, it made 180hp but that was without the cams or plenum.
Um, are you wearing fingernail extensions???
Thanks
i find that pic a bit hard to beleive, it reckons you only need springs and retainers with 10mm plus lift, they start spitting shims 9.5 or so
at first i had a laugh at this, then noticed both hands holding the paper have the same nail extentions.........its his gf most likely
