Results 1 to 3 of 3
Thread: Ke70 ---> SR20 conversion steering rack clamp sizes
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    Default Ke70 ---> SR20 conversion steering rack clamp sizes
    hey all
    just thought id put up a finding for some of you doing SR conversions into ur ke70 (maybe ae86 too)
    upon installing my sr today i noticed the sump was fouling on the drivers side steering rack mount. i knew it didnt touch in the other car but i had changed to an ae86 steering rack and polyurethane mounts. my first thought was that the 86 rack was larger around the clamp area but after pulling it out it was the same.
    what i did find was that the ke70 uses a thinner rack bush and smaller clamp letting the clamp sit lower against the rack.
    like this
    ke top, ae86 bottom
    so after changing to the ke rack bush and clamp it went back in although it did still need a lil clearancing (read: grinding). has a good 10-15mm clearnace now
    i thought this may help a few of you who might have trouble getting urs to fit.
    craig
    Veteran Skylar's Avatar
    Ken
    Just to clarify, can you confirm that AE86 and KE70 racks are the same size at the rack bush? Only the rack bush and clamp are different in size.
    Sep 2010
    Craig
    Perth hills
    yes i can confirm. i had them side by side today. i will double check tomoz with a tape just to be sure cause it was by eye today. i have another ke rack sitting here somewhere too
    the ke rack bush was definitely thinner but ( bout half the thickness) the passenger side bushes are the same on both
  • Similar Threads
    1. KE70 Dash Cluster Setup with SR20 Conversion
      By luke04 in forum Technical - Questions
      Last Post: 25th October 2012, 01:16 PM
    2. ke70 steering rack
      By doots in forum Technical - Questions
      Last Post: 4th May 2010, 12:35 PM
    3. rack end and rack bush for ae86 power steering rack
      By quoccy in forum Cars or Parts Wanted
      Last Post: 28th June 2008, 12:58 PM
    4. JDM GTV/GT-Apex Steering rack
      By ae86hachiroku in forum Technical - Questions
      Last Post: 21st July 2007, 04:58 PM
    5. SR20 KE70 backyard conversion?
      By -=GOODY=- in forum Technical - Questions
      Last Post: 18th April 2007, 10:38 PM
