Results 1 to 10 of 12
Thread: 4AGE Carb ignition setup
    Senior Member stixy's Avatar
    Queensland
    The mount
    Brisbane, Queensland, Australia, Australia
    Default 4AGE Carb ignition setup
    Hi all,
    Ok, so im doing a carb conversion on my 4AGE, now i have done a bit of reading on what to do with the distributor, now i have read that you can use the guts out of a 4kc as such.
    I would just like to know exactly how to modify the dizzy, has anyone got any pics and a write up??
    Also how far of would a 4AC dizzy be from using??
    hmm??
    Thanks all =D
    Sep 2011
    Joey
    Queensland
    North Brisbane
    Been researching this myself and from what I can surmise:
    - 4k is the most often used, needs an adaptor plate which can be purchased pre fabricated for varying prices overseas. May or may not need a new gear idk.
    - 4ac spins the opposite way but some sources seem to say that is due to the dizzy gear. Would need the same modifications as 4k dizzy, and is rather bulky.
    - Most people seem to just get a older style 4ag dizzy and lock it at a certain ignition advance with an aftermarket ignition module, eg bosch.
    I'd link you the pages I got this info from but cbf. Need someone who has actually done it and knows what theyre talking about to reply . There was a guy in brisbane city whom I bought parts off, who had a single weber downdraft and locked 4ag dizzy on his ae71, pretty cool.
    - Also there are other aftermarket electronic options that offer ignition advance, and there is one for 300 aus on ebay from nz that offers ignition advance of the stock 4age dizzy.
    Junior Member filfrederick's Avatar
    Jan 2010
    Phil
    Taringa
    I used a 4k electronic distributor that i bought brand new for around $120 and pull the shaft out and machine it to suit a 4age distributor gear that you can buy new from Toyota.
    then I machined a aluminum sleeve that enlarges the part with the o-ring that seals into the head.
    then drill and tap a new retainer bolt hole into the head as the 4k slot is further in toward the bore.
    I have done a few this way and they sit in a lot further in than using an adaptor plate so there are less issues with it fouling on the headers.
    might be able to help you out if you want, for a price of course
  • #4
    Queensland
    The mount
    Quote Originally Posted by undercoverninja View Post
    Hmm night have a look for one.
    Quote Originally Posted by filfrederick View Post
    Intersting..... what would you need me to supply? (4k elec dizzy 4age dizzy) also what sort of price are we looking at here? PM if ya like
  • #5
    Jan 2010
    Phil
    Taringa
    Pm sent
  • #6
    Moderator Sam-Q's Avatar
    Endeavour Hills
  • #7
    For the money being spent in half ass setups, I'm not sure why you wouldn't speak to performance ignition and get a scorcher distributor or other option from them...
  • #8
    Senior Member 4A-GE Power's Avatar
    Daniel
    ^^^yeh true.
    Thats what i did. I did try and get an optical ignition to work but it was far too unreliable so i just got a scorcher distributor from performance.
  • #9
    Senior Member cooter's Avatar
    Sep 2010
    Craig
    Perth hills
    Hey all found this on google. thought it might help explain a lil bit what others have said
  • #10
    Member Golden Circle's Avatar
    Oct 2011
    Clinton
    Hills District
    you could use a stock 4AG dizzy and get one of those ecus from new zealand if youre a real tight arse.
  • Page 1 of 2 1 2 LastLast
    1. Replies: 2
      Last Post: 9th December 2012, 12:21 PM
    2. Replies: 2
      Last Post: 3rd November 2011, 06:43 PM
    3. Carb'd 4AGE on Hyperpak ignition no spark problem
      By 4AGE FORD in forum Technical - Questions
      Last Post: 20th January 2011, 06:06 AM
    4. Carb setup
      By xdanielx in forum Cars or Parts Wanted
      Last Post: 15th June 2008, 10:04 PM
    5. Carbs, 4age carb manifold, jaycar ignition
      By quoccy in forum Car Parts For Sale
      Last Post: 19th June 2007, 10:50 PM
