Results 1 to 10 of 13
Thread: Ae86 wheel offset problems... HELP
    Junior Member Hella86's Avatar
    Apr 2011
    Joel
    Default Ae86 wheel offset problems... HELP
    Hi guy,
    i have been building a 86 up for the last 4 years started off pretty much back at a shell... I'm now up to the wheel stage and what I want to know is what's the biggest wheel offset u can fit under a 86 with out hitting suspension set up...
    so I'm running semi factory set up.. King springs with KYB shocks.. And I want to fit 15x8-4 front and 15x10-12 rear... Can I do so with this set up or do I need to upgrade to coilovers?
    guards are crazy big so no problem there!!
    any help would be great guys cheer!!!
    Aug 2010
    Geoff
    mt dandenong
    Should be fine, you should look to upgrading to coilovers in the future, king springs with those wheels and you will get mad wheel rub
    Apr 2011
    Joel
    Yer I was looking at upgrading... That will be the step after body work and paint.... Any coilovers u recommend?
  • #4
    Aug 2010
    Geoff
    mt dandenong
    shockworks, mid priced but great quality.
    make sure you pre fit your 10"wide rear rims before you do your body work, you'll need to pump your guards for those rims. be smarter to go with 8" all round to be honest, cheaper better fitting tyres and you wont have to hack up your body.
    just my 2c
  • #5
    Apr 2011
    Joel
    Rear guard work has already been done fronts still need to be sorted... I had 8's on it and wasn't happy with the look... Cheers for the advise
  • #6
    Moderator
    Jay
    are going to have longer front lca's to even out the track or something?
  • #7
    Apr 2011
    Joel
    Coilovers are now ordered... Yes as for lca's I looked into the xt130 and sigma but missed out on the sales.. What lca's do most use
  • #8
    Aug 2010
    Geoff
    mt dandenong
    Nice. Which coil overs? Xt130 are the go for lca
  • #9
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    XT130's won't make up for the difference in rear track with your wheels, I find 86's steer a bit off when the front track doesn't at least match the rear.
  • #10
    Apr 2011
    Joel
    Quote Originally Posted by dove grey 64 View Post
    I picked up a set of driftworks coilovers..
  • Page 1 of 2 1 2 LastLast
    1. Ae86 wheel offset ?
      By AIROCOBRA in forum Technical - Questions
      Last Post: 5th May 2009, 12:28 PM
    2. Wheel offset calculator
      By Jarrod in forum Technical - Articles
      Last Post: 23rd September 2008, 07:06 PM
    3. Wheel Offset Calculator
      By 741 in forum General Topics (No Technical Questions)
      Last Post: 16th December 2007, 03:49 PM
    4. Wheel Offset
      By nightdevil in forum Technical - Questions
      Last Post: 4th December 2005, 09:46 AM
    Tags for this Thread
