Any rego? Also any real issues for RWC?
Backup for sale because this thing never got much use.
Originally:
Toyota Corolla CS AE71 silver
rear 4.1 auto diff
165,000kms
rego till Oct 2013
paint is abit shit due to grandpa bad eyesight respray and rust repair
diy rust repairs and it growning back (around boot, petrol cap, rear driver roof, rear tailgate)
missing passenger side bump strip (fitted an AE86 bump strip!)
no aircon (cs model)
non adjustable steering colum (cs model)
no petro release (cs model)
Mods:
AE71 Manual conversion (pedal box, ae86 gbox, ae71 gbox xmember, ae71 tailshaft, 4ac manual flywheel/clutch, spigot bearing)
reverse lamps hooked up to a switch (gbox switch connector broken)
original 4ac with secondary spring mod, ERG valve block off, 2" redback sports muffler
new timing and alt/waterpump belt
new oil filter, 20w50 oil, bosch sparkplugs , dizzy cap, dizzy rotor and fuel filter.
AE71 CSX driver side mirror
AE71 tacho dash cluster and digital clock! with original speedo installed
AE71 Spirit style windows
narva rear stop lamp
LA Ink seat covers (classy)
Jcar remote boot release kit (cs model)
Orange foglamp kit
AE71 towbar with wiring (hooked up and working)
AE86 KYB Potenza Gymkhana 4way adjustable rear shocks (for towing or more)
cut ae71 springs (1 coil so nothing crazy)
14x6+10 Performance alloy wheels with vgc 195/60r14 tyres
Starlet steeringwheel (horn broke on the stock wheel)
Comes with rwd 4age
4AGE bluetop early Bigport (unknown condition, was going to strip and rebuild the original 4ac with the 4age parts)
4AGE Loom modded
AE86 RWD Extractors (no oxy or secondaries)
AE86 RWD intake manifold
the bad - paint job not the best, light rust regrowning (fuel cap, boot area), speedo off (need 3.9 ratio diff, but 4.1 will drop mad skids), center console abit shit, crack mirror on passenger side, gbox reverse switch need to be replaced or fixed and light passenger side damage that was cheaply repaired (cosmetic, passed rwc previously)
(going to be honest here, nothing to hide, except for burnouts)
starts easy, drives well, has stock crappy brakes, pulls hard (but still shitty)
SOLD
30kw club
WHy do ytou keep doing this with your corollas leo, bring it out for a drive through the hills! Either way that's a bargain with the jdm brakes and whiteline gear.
mate, I make this mistake so many times iv lost count LOL, but ill just get an ae86 and be done with it.
not to sure whats needed for rwc, passed in feb with stock items (which are supplied btw)
30kw club
bump
30kw club
Where about's in Victoria are you located?
Do you have any idea what is needed for a RWC? If so could you get one?
What do you want for the car & the 4AGE
Cheers, Dylan
$2500 with 4age gear.
was going to strip the 4age block and reinstall everything with a new vrs kit on the 4ac to retrain the factory engine number (ideal for p platers)
30kw club
bump for 4AC power
30kw club
bump
30kw club
bump
30kw club
