Results 1 to 10 of 10
Thread: Anyone used these 4age cams?
    Jul 2009
    Joel
    Taree
    Default Anyone used these 4age cams?
    hi I just wanted to know if anyone has ever put these cams in there 4age are they good for the money
    any info would be good thanks
    http://www.ebay.com.au/itm/JASMA-Hig...item5651d3f3fb
    My personal opinion is you pick the cams last...
    Once you've done the light weight flywheel, higher comp pistons, head work etc.
    264 is not an overly agressive cam and similar in size to what is found in the 20v's.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    "Jasma" is a made up brand playing on the Japanese government department that certifies aftermarket parts with the same name. The brand and parts they produce are rubbish, I would reccomend you steer well clear. Stick to a well known brand name and you will be far better off.
  • #4
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I've never used them myself, but all reports I've heard on Jasma camshafts are that they are not the greatest....
    From memory, a few months ago, there was a guy on here trying to sell those Jasma cams on this forum, and if you read that, you will see that NO ONE wants them........
  • #5
    Adan
    Oxley Park
    Yep I was going to say the same as JoJo.
    If you have money burning a hole in your pocket, then go get them and let us know how they are. They will either go well in the engine, or be pretty good door stops.
    If your on a budget and dont feel like experimenting, Id probably keep away from them...
  • #6
    Kelford or even second hand HKS cams are a fairly well priced option.
    http://www.kelford.co.nz/camshafts
    Toda are exy.
  • #7
    Jul 2009
    Joel
    Taree
    Quote Originally Posted by Matt View Post
    Toda are exy.
    ok cool thanks everyone
  • #8
    Veteran blair's Avatar
    Blair
    Sheldon
    Just got quoted 590 delivered for a set of Tomei PONCAM 264's (the easiest 'drop in' cams designed to work on stock timing and ecu etc.)
    Through Jesse Streeter of course.
  • #9
    Veteran stahlz_ae86's Avatar
    Paul
    Also might be worth looking at wade cams too, I'm going to price up some 267 degree cams soon from them.
  • #10
    Veteran slide86's Avatar
    Huw
    Hills
    Quote Originally Posted by blair View Post
    Very well priced. God bless the YEN at the minute.
    (Might buy myself a pair and put them on the shelf)
  • Similar Threads
    1. 4age cams
      By yusoff in forum Cars or Parts Wanted
      Last Post: 20th May 2013, 03:24 PM
    2. 4age 16v cams please
      By stixy in forum Cars or Parts Wanted
      Last Post: 14th May 2013, 05:44 PM
    3. 4AGE Camtech Cams
      By Bart in forum Car Parts For Sale
      Last Post: 23rd September 2009, 07:13 PM
    4. Bigport 4age Cams
      By 70XIN in forum Car Parts For Sale
      Last Post: 19th August 2007, 12:56 PM
