Results 1 to 6 of 6
Thread: Chasing lock... What parts do I need and what are you using?
    Nathan
    Default Chasing lock... What parts do I need and what are you using?
    Finally got around to working on my old KE70 after 3-4yr of not touching it.
    I'm working of front steering and what parts will I need to it all work.
    I already have:
    AE86 steering rack
    AE86 castor arms
    AJPS bolt on + slip on rack spacers
    AJPS 40mm rcas
    JDI AE86 knuckles
    RT132 front LCAs with lock stops cut off
    RT132 struts
    What Rack ends and tie rod ends do I need up use this setup?
    i heard RA60 tie rod ends but not sure what tie rod ends.
    what other parts is anyone using for more lock?
    Veteran Konakid's Avatar
    Henry
    Eastern
    You wont need any more lock than that. That is a shitload. You dont even need that much. Just the JDI arms and lock spacer is heaps.
    Veteran KurtHS's Avatar
    Kurt
    East Melb
    Yeah man that'll have sweet lock you won't need anymore!
  • #4
    Kurt
    East Melb
    Just be mindful of the size and offset of your front rims, with that much lock you might come into scrubbing issues. I have 15x8 -0 and scrub heaps on the chassis, it's the worst when I loop it on lock, takes chunks out the tyres sometimes.
  • #5
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    I use standard tie rods and rack ends with similar set up
  • #6
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    As said before youre going to need an aggressive offset so it clears the chassis and probably bash parts of the body out where tubs should be. if youre wheels arent aggressive enough offset youre going to need lengthened LCA's to increase the track abit where ra40 or ra60 even rt142 tie rods will be used with an rt142 tierod tube.
  • Similar Threads
    1. Chasing Coilovers, strut braces, etc for Ke70, 4age conversion parts.
      By chrisfindlay in forum Cars or Parts Wanted
      Last Post: 1st March 2012, 06:22 PM
    2. chasing some driveline parts
      By thatAE71 in forum Cars or Parts Wanted
      Last Post: 14th November 2009, 11:46 AM
    3. Chasing some stock parts. [WA]
      By AE86 Spoontah in forum Cars or Parts Wanted
      Last Post: 6th November 2009, 09:56 PM
    4. T50 Parts - Reverse Switch & Speedo Drive Lock Tab
      By Trev084 in forum Cars or Parts Wanted
      Last Post: 12th April 2009, 11:02 PM
    5. Buddy Parts Lock Spacer
      By sonsta in forum Car Parts For Sale
      Last Post: 4th April 2009, 04:03 PM
