Results 1 to 10 of 12
Thread: Has anyone done a coil over conversion on ae86 ADM
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Default Has anyone done a coil over conversion on ae86 ADM
    Have standard diff and drums on back with shocks and looking to install https://technotoytuning.com/toyota/a...n-ae86-corolla plus the disk brake kit on rear from same guys has anyone done this.
    Aug 2010
    Geoff
    mt dandenong
    You'll need to ask them if their disk brake kit will suit a sr5 diff, same as adm diff. They had a gts corolla which had a t series. The mounting holes are different between both diffs. Some people here run a coilover/spring in one unit, I don't see the benefit
    Elite rthy's Avatar
    Leo
    Tulla
    those coilovers may bolt on as it depends on the mounting angle and brakes mostlikely won't as it won't have a backing plate for the caliper.
    Would end up being cheaper to buy a jdm rear end with lsd
  • #4
    Mar 2013
    Mirko
    Yeah that's what I was thinking. Now to find a jam rear for sale
  • #5
    Julian
    Northern suburbs
    Ive got a JDM T series diff with discs for sale if you need one, in Melbourne though. send me a PM if your interested
    Rust is a way of life
  • #6
    Sep 2009
    Rohan
    northshore
    the BC coil over kit fits with no problem the only thing i would change on the diff is the panhard rod and all the bushes in the car to get the full advantage of coil overs
  • #7
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I don't know if this is true but apparently you need to chop into the body to fit the T3 coil-overs. That said why wouldn't you just fit the completely superior Shockworks parts?
  • #8
    Mar 2013
    Mirko
    Thanks for the help boys. So yeah thinking of the options jdm or f series just seeing what's out there not chasing huge power but will get used on track days a lot so needs to take it
  • #9
    Endeavour Hills
    JDm diffs are worth heaps and the LSD's in them if their original are almost guarenteed to be stuffed, to top it off they have small rotors and tiny calipers.
  • #10
    if you are tracking it go shockworks coilovers.
  • Page 1 of 2 1 2 LastLast
    1. Coil over conversion
      By wild_70 in forum Technical - Questions
      Last Post: 26th February 2013, 01:23 PM
    2. Replies: 0
      Last Post: 24th June 2012, 12:57 PM
    3. ADM AE86 (Trueno Conversion)
      By jonbatz01 in forum Cars for Sale (Toyota Only)
      Last Post: 16th June 2011, 03:30 AM
    4. adm ae86 trueno conversion $4.5k ONO
      By phivrne in forum Cars for Sale (Toyota Only)
      Last Post: 16th December 2010, 01:46 PM
    5. dizzy - coil pack conversion
      By tim.duncan in forum Technical - Questions
      Last Post: 25th June 2008, 06:20 PM
