Results 1 to 9 of 9
Thread: 4age Smallport - Relocate intake butterfly to outside centre position instead of end
    Mar 2012
    Craig
    Surrey Hills
    Default 4age Smallport - Relocate intake butterfly to outside centre position instead of end
    I notice the cut and shut option for the 4age intake manifold is widely used; however, I just want to know if anyone has relocated the butterfly module to the outside centre of the plenum chamber? My theory is the flow may improve if the butterfly is central to the intake tubes.
    Thoughts anyone?
    May 2012
    ACT
    belconnen
    Not really going to make a difference. The only restriction of flow into the manifold is pretty much just the throttle body itself, but its hardly a problem until the engine makes a lot of power.
    The best place to put the throttle body is where its most convenient.
    Aug 2010
    Geoff
    mt dandenong
    Due to the size of the intake tunnel if you place the throttle body where your thinking you would most likely only feed air to 2+3.
  • #4
    Mar 2012
    Craig
    Surrey Hills
    Sam: I agree, if the internal profile of the plenum chamber is symmetrical?
    Geoff: I notice Ford runs a centre feed module on the six cylinder, so I don't think the flow will be compromised on a 4 cyl unless the plenum chamber is not symmetrical.
  • #5
    Aug 2010
    Geoff
    mt dandenong
    true
  • #6
    Veteran johl's Avatar
    Johl
    from memory i wouldnt think there would be enough room between the inlet manifold and strut tower. imo its not worth doing, i would prefer to put itb's on it instead
  • #7
    Mar 2012
    Craig
    Surrey Hills
    I like the ITB option too Johl; however its going into a Triumph Spitfire and I would have to modify the firewall to make room for the rear throttle body, not a big problem though. I have plenty of room on the outside and front of the manifold.
  • #8
    Johl
    That's awesome. What generation spitfire? Sounds like a great platform to put a 4age into a 700kg car
  • #9
    Mar 2012
    Craig
    Surrey Hills
    Mk 4 ~1974, but she is a bit like grandpa's axe that had three handles and two heads...
    Tried to load a photo; however no luck, not sure what I am doing wrong!
  • Similar Threads
    1. smallport intake, throttle body & 4age sump
      By gaz20v in forum Cars or Parts Wanted
      Last Post: 15th October 2009, 06:17 PM
    2. 4age bigport head on smallport bottom end
      By riojin in forum Technical - Questions
      Last Post: 14th September 2008, 11:29 PM
    3. 4age smallport bottom end complete. pics and receipts
      By Benny AE71 in forum Car Parts For Sale
      Last Post: 10th July 2008, 07:12 PM
    4. smallport intake manifold
      By julzy in forum Cars or Parts Wanted
      Last Post: 13th December 2007, 04:40 PM
