Results 1 to 10 of 10
Thread: Paint Preperation Tips n Tricks
    Default Paint Preperation Tips n Tricks
    This thread is for all those tips / links to videos about prepping a car for paint. Start a new thread for specific how do i fix this rust question.
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    The more time u put into the prep work, the nicer the job will turn out. There is no way to short cut this process so don't try too
    Senior Member mcBen's Avatar
    Mar 2012
    Eastern burbs
    I'm painting the underbody of my car and I'm wondering what's the best way to get all the grease off, I don't really want to high pressure hose it because there are rust repairs and bare metal around that water will get into ..
  • #4
    Mar 2010
    Brett
    Crestmead
    The easiest way is to high pressure blast it. First spray ur entire area in degreaser or diesel. Let it sit to loosen off all the shit and hose it off. Unless u want to get under it with a scrubbing brush and a bucket.
  • #5
    Mar 2012
    Eastern burbs
    Quote Originally Posted by haveaparty View Post
    Tried that but it sucks ass.. think Ill just high pressure and then put my car in a giant bag of rice
  • #6
    Dec 2012
    Ethan
    gawler
    pressure wash it, dry it out with compressed air...
  • #7
    Aug 2012
    Jarrad
    east
    General run-down of what is generally done in the industry/what used to be done. A lot of panel shops don't wet sand anymore. It gives a much better finish.
    From bare metal:
    Undercoat/primer
    Light spray of black guide-coat
    Wet sand 400 grit
    Lightly wipe a rag with paint over sanded area.
    Wet Sand 800 grit
    Wipe with prepsol/cleaner, wipe off right away with a clean rag
    Right before paint, rub all surfaces to be painted with a tack-rag.
  • #8
    Mar 2010
    Brett
    Crestmead
    From bare metal. If no repairs are required. Then a coat of etch primer and paint straight over that is fine. If repairs then prime with gide coat.
  • #9
    Mar 2012
    Eastern burbs
    Also my paint has some orange peeling. I was wondering if I did a wet sand with 1200 - 1500 grit would that take away the clear coat?
    Sent from my LG-P990 using Motorculture mobile app
  • #10
    Mar 2010
    Brett
    Crestmead
    Yes it will take away the clear coat. U will need to buff it up with a cutting compound followed by a polish. Orange peel is normal tho.
  • Similar Threads
    1. Brake Installs Tips, tricks and products
      By motorculture in forum BENDIX Put your foot down with confidence.
      Last Post: 16th November 2012, 03:54 PM
    2. Handbrake lock tricks
      By ae86 slide in forum Technical - Questions
      Last Post: 26th January 2010, 08:46 PM
    3. Quotes and Tips on paint job
      By adjo1989 in forum Sydney & NSW Events and Discussion
      Last Post: 5th April 2009, 08:56 PM
    4. Hachis ain?t s**t but hos and tricks
      By marvis in forum Offtopic Discussions
      Last Post: 18th February 2009, 08:00 PM
