Results 1 to 2 of 2
Thread: Tools to purchase for Panel Beating
    Default Tools to purchase for Panel Beating
    Hammers / Dollies
    When picking a hammer / dolly the best you can buy are the sykes pickavant range. These are perfect if you are in the trade and use them all day every day. The set you buy will last you from your first day until the day you retire.
    However, for the home handy / hobbyist , something middle ground will last you as well the same time.
    When purchasing dollies it is reasonably safe to assume that the heavier the dolly the better it is.
    [img]http://thumbs2.ebaystatic.com/d/l225/m/mgojNcXsRaFdGue3chxV3qA.jpg[/url]
    Jefferson Paint Supplies in melbourne have some good equipment at reasonable prices.
    Pullers
    Slide hammers
    Clamps
    Welder
    Other Bits
    Senior Member K1W1 Simo's Avatar
    Dec 2012
    Simon
    Mt Coolum
    SPOT WELD DRILL BIT
    These are such an important tool if you are full on unstitching your panels from your body. A dot punch is needed to start at the centre of the spot weld. You will be left with a surface to weld new/restored panels onto, instead of holes where your drill has gone right through.
  • Similar Threads
    1. Should i purchase?
      By joshdanks1994 in forum General Topics (No Technical Questions)
      Last Post: 13th April 2013, 01:02 PM
    2. Panel Beating cash job
      By haydenz in forum Melbourne & Vic Events and Discussion
      Last Post: 7th December 2010, 06:19 PM
    3. WTB: Panel beating stuff
      By opedhead in forum Cars or Parts Wanted
      Last Post: 13th April 2009, 11:53 AM
