Results 1 to 10 of 14
Thread: Leaking water pump?
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Default Leaking water pump?
    hey dudes, was working on my ae and noticed that under the water pump ther was a small hole witch leaks coolant out of, can i just plug this or is there something wrong with the gasket u guys think??
    Heree have a look.
    http://i1300.photobucket.com/albums/...ps0b7df20b.jpg
    thx again
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    I should add that I am running an inline thermostat aswell that goes from the water pump straight thru to radiator with no bypass anywhere.
    Senior Member Dylan's Avatar
    Dylan
    You'll need to replace the waterpump, when it leaks out of that hole the seal around the bearing has let go.
  • #4
    Veteran slide86's Avatar
    Huw
    Hills
    Yep. That hole is there for a reason.
    Dont drive it until you have put a new pump on it.
  • #5
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Thanks. Is there any difference in which qater pump to get?? A genuine touota or something generic because they are alot cheaper.
    Thrre are some by gates too and they are also cheaper than genuine toyota.
  • #6
    Member gaspal's Avatar
    Richard
    Osborne Park
    Coming from a mechanic, i dont trust anything other than genuine when it comes to the cooling system. Hoses, thermostats or water pumps, go genuine for piece of mind, its worth the little bit extra. Also make sure to clean up the mating surface on the block properly and put a slight smear of quality sealant on both sides of the new gasket (which should come with the new pump).
  • #7
    Huw
    Hills
    Quote Originally Posted by gaspal View Post
    Coming from ANOTHER mechanic, everything above is 100% right and I agree
  • #8
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Using a quality pump like genuine or GMB, and you won't have a problem.
  • #9
    Oct 2011
    Tore Daniel
    Norway
    Norway
    Norway
    What everyone said, OEM works best, or manufacturers that goes by strict OEM standards, i.e Aisin and the likes.
  • #10
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I should be able to source them for about $110 for the front and back halves together
  • Page 1 of 2 1 2 LastLast
    1. Car leaking water..!?!?
      By adds in forum Technical - Questions
      Last Post: 19th April 2013, 08:03 AM
    2. Replies: 0
      Last Post: 7th October 2011, 07:37 AM
    3. WTD, 4age water outlet, the one above the water pump
      By gaz20v in forum Cars or Parts Wanted
      Last Post: 11th December 2009, 11:56 PM
    4. water leaking from copper plug
      Last Post: 7th March 2008, 06:57 PM
    5. Water Leaking Into Car
      By Age86 in forum Technical - Questions
      Last Post: 11th September 2006, 12:31 AM
