Results 1 to 10 of 13
Thread: 3sge beams altezza fuel pressure
    Junior Member JOshua a's Avatar
    Dec 2012
    Joshua
    Ontario
    GTA
    Canada
    Default 3sge beams altezza fuel pressure
    So I got a 3sge beams in my ae86, I was wondering what people are running for fuel pressure? I heard of some people running 40PSI, others 60PSI. I'm not sure what to run. I'm currently putting my fuel setup together now with a walbro 255 in tank, with a return line setup back to the tank. I'm also running full vipec V44 standalone with ITBs if that makes a difference. Some input is appreciated.
    Josh
    Evan
    Ballarat
    Altezza factory fuel pressure is 62PSI, I have been running this in my Beams AE86 without issue.
    Glenn ke_70's Avatar
    Clay
    Barossa!
    62 stock with returnless.
    i've dropped mine down to 40ish psi with a return line.
    Dec 2012
    Joshua
    Ontario
    GTA
    Canada
    I will also be running a return. So should I set mine to 40ish as well?
    Senior Member BEAMS_86's Avatar
    Jan 2013
    Elanora
    I'm running 50psi in mine But still yet to tune it that's just what we set it at for now.
    Mt Macedon
    If you're running aftermarket or standalone management then the precise fuel pressure you set is largely irrelevant. High enough for a good spray pattern and enough flow through the injector, low enough so you're not pressing your pump too hard. Then you tune the ECU to supply the right amount of fuel.
    Dec 2012
    Joshua
    Ontario
    GTA
    Canada
    So set mine up for 42 and tweak it when I get a tune
    Clay
    Barossa!
    yeah pretty much what hen said.
    i just used 40psi because that was what the startup/base tune was tuned to.
    Dec 2012
    Joshua
    Ontario
    GTA
    Canada
    Alright. Thanks homies.
    any update on your awesome build Glenn?
    Clay
    Barossa!
    who's glenn?
  1. WTB: 3sge/beams fuel pressure regulator
    By zacha86 in forum Cars or Parts Wanted
    Last Post: 14th January 2013, 05:46 PM
  2. altezza 3sge beams motor
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 11th February 2012, 11:58 AM
  3. wtb 3sge altezza beams
    By Celica RA45 in forum Cars or Parts Wanted
    Last Post: 22nd January 2011, 06:07 PM
  4. 3sge altezza BEAMS pistons and rods
    Last Post: 15th June 2010, 11:23 PM
