Results 1 to 4 of 4
Thread: Axle question. Do Celica T series axles fit a Corolla T series?
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default Axle question. Do Celica T series axles fit a Corolla T series?
    Hey guys,
    I am in a big rush this week (getting ready for Drift fest 02), and I am looking some quick help..... I dont have time to be doing unnessary jobs, trying differant things etc....
    Anyway,
    What I am needing to know, is if RA60 Celica drum brake axles, can be used in a Corolla T series?
    I will be using a TRD 2way, so I believe I might need to cut a small amount off the axles, thats no biggie, but i am not sure if the axle collars/bearings etc are compatible.....
    Muchly appreciated
    JoJo
    Oct 2011
    Tore Daniel
    Norway
    Norway
    Norway
    Quote Originally Posted by maxhag View Post
    Hey guys,
    Anyway,
    Muchly appreciated
    JoJo
    If you mean a complete A60 rear axle then yes it can be used if you weld on mounts to suit your car.
    If you wanna install a LSD then remember it has to be for Zenki-type, and as you said, shorten halfshafts.
    But if you mean use drum brake halfshafts into AE86 Zenki diff I really dont know and would like to know as well as I am facing similar logistical issues in getting cheap replacement halfshafts!
    Mt Macedon
    Yes everything works fine. They just need 10mm trimmed from the end (not because of the LSD thing, but RA60 axles are just 10mm longer than T18 axles). So:
    1 - Pull out RA60 axle at wreckers
    2 - Trim 10mm off the end
    3 - Install into your T18 housing
    4 - ???
    5 - Profit
  • #4
    JoJo
    ACT
    Tuggeranong
    I have a RA60 in my yard that I am wrecking, so this is perfect.......
    I will remove them and trim them down tomorrow....
    Thanks Hen
    (Tore - I was just talking axles only)
  • Similar Threads
    1. Replies: 1
      Last Post: 15th January 2012, 09:11 PM
    2. Replies: 3
      Last Post: 26th April 2011, 12:30 AM
    3. will a t series lsd centre fit in a s series diff?
      By angelo in forum Technical - Questions
      Last Post: 2nd July 2009, 08:21 PM
    4. T series axle question
      By ke25 racer in forum Technical - Questions
      Last Post: 29th August 2008, 07:44 PM
    5. t series axle, or axles.
      By Trucka 115 in forum Cars or Parts Wanted
      Last Post: 20th July 2007, 10:52 PM
