Id put money on still being able to get them through toyota
I'm having trouble locating new Silvertop ITB throttle body to manifold gaskets, I note the originals are a metal compression design which I assume are disposable after disassembly. Has anyone had success with alternative materials such as standard gasket paper or perhaps Teflon sheet?
I thought so, but apparently none in country and ETA of 3 plus weeks threw a spanner in the works!!
Sam q should have these
Sam is out of stock Geoff
i have heaps of these ,but you can use some toyota packing on both sides to reuse again if you wish ,just a small smear will do
If it's just an inlet gasket I can't see why you couldn't make the gaskets from sheet? It's not exactly a difficult process.
Try Toyota NZ.
Failing that, get one posted over from NZ. 20vs are regularly at wreakers.
Thanks for the feedback everyone...
These parts are readily available, if you need them just pm me.
