Hey all, im putting up for sale the grey starlet that i bought in Nov '11. It is currently not running however is very, very close to. I will try and kick it over in the next couple of days and get the dash all screwed back together. The missus and I split up during the week so i need to get rid of this ASAP so i don't have 4 cars to move with me.
If you check out my Toymods members ride thread you can see the work I have done on this.
I bought it with a mess of wiring - this has all been rectified (fuse box in the engine bay where it should be. All live wires terminated, bad soldering/taping fixed). It had a jumbo inlet and cooler which i have since changed for a stock inlet, smaller cooler. I have relocated the coils to a better area and used a more secure bracket. I have replaced the cracked/leaking heater core. I was hoping to get it finished and back together properly before I sold it but can't do that now.
This would make an awesome project for someone to finish up or a cheap way to get a stack of awesome upgrades for a stocker/EP91 conversion.
Price:$3.5k as is.
Engine:
Hpc coated, Custom exhaust manifold
Garrett GT2560r (.64 rear)
Custom 3" exhaust w/ high-flow cat & turbosmart muffler
Just Jap FMIC and HDi piping kit (modified hot side)
440cc injectors
Custom fuel rail & brackets
Moroso fuel pressure regulator
Speedflow fittings used throughout whole system
Flame-proof 3/8" fuel lines
Upgraded fuel filter
Custom surge tank
external Bosch 044 fuel pump
Walbro in-tank pump
Microtech LT10s ecu
X4 ignition module
Bosch individual coil-packs
NGK plugs
PWR radiator w/ 12" thermo fan
Remote oil filter setup (braided lines/speedflow fittings)
Lightweight crank pulley
TRD engine mounts
Direct Clutch Service custom clutch & pressure plate
Lightened flywheel
TRD clutch-type LSD
Brakes & Suspension:
Slotted rotors front
GAB Height/Damper adjustable coilovers
Whiteline rear sway bar
Whiteline rear strut brace
Whiteline anti-lift/castor kit
Whiteline panhard rod
Lightweight 16" starcorp rims (needs tyres)
Interior:
Brand new pedal rubbers
Relocated battery in boot (enclosed)
CD/MP3 player
Mod plated as 2 seater - rear seats and boot carpet gone.
Interior very neat, no holes, tears, burns etc.
To finish:
At present this needs a little bit of work to get back to fully functional. Dash/consoles screwed back in. Head unit/speakers put back in. Intake air temp sensor bung welded to cooler piping (for fitment of bosch screw-type sensor), brakes bled, washer pump wiring extended. battery, Wash/vac.
The car is located in Pascoe Vale Sth, Vic. Pictures upon request. I cant find my camera cable at the moment.
Happy to answer any questions you may have, will take viewings and have nothing to hide.
I also have a few add-ons you may want that i can sell. Oil cooler, catch can, 2x bucket seats, 2x harnesses, Apexi POD filter, manual boost/screw valve, BOVs, a couple of gauges....
Cheers guys,
Stu
0415 298 248
Price drop - Im not going to time to work on this guys. I'm shifting my stuff out this week so really need this gone. I can bolt everything back in so it can be steered onto a trailer etc but no time to get it going. I tried to crank it today - cranks ok but no start. Dont have time to track it down. As it stands for this price you are getting a bargain in parts as is. Wheels, motor, turbo gear, LSD box, cooler, radiator, coilovers, rims, strut and sway bars, external fuel pumps...........
Help a brother out of a shitty situation
Stu
0415 298 248
