hey mate can u send some pics please and a price on the whole lot ???
Item: Smallport 4AGE, was apparently rebuilt 5,000 k's before I got it and I've probably done 2,000 k's with it, so around 7,000 k's on the engine. Always well serviced, consistent oil changes etc.
-Has cut and shut smallport intake manifold, can come with customised VN air box and fresh air duct.
-Complete RWD water system.
-4-2-1 extractors, very nice set of pipes which lead into a pretty much brand new, mild steel, 2" over diff exhaust system. The exhaust has one resonator (hotdog) and one muffler, awesome note, can be quiet at low RPM or pretty loud when you punch it. The exhaust is tucked up really high, it's very well made. To suit KE70/AE71.
-Lightened flywheel, heavy duty clutch, T50 gearbox in good condition, doesn't slip out of gear or crunch any gears.
- One piece tailshaft to suit T50 to T series diff.
This engine pulls really hard, it's definitely one of the fastest 4AGE powered cars I've been in, the engine is currently running in an AE71, it will come with everything you need to make it run in your Corolla, TEST DRIVES ARE WELCOME.
Price: $2000 for the engine + $600 for the tailshaft and exhaust.
Item: JDM AE86 T series disk brake rear end, near new pads, near new discs, rebuilt calipers, all handbrake cables, braided brake lines, TRD 2 way LSD which is very tight and locks up very well, genuine Toyota 4.7 ratio crown wheel and pinion, doesn't whine, the gears are like brand new. Diff has been rebuilt with a solid spacer rather than a crush spacer so it's far more reliable than using a crush spacer which tend to continue being crushed when driven hard and eventually pull the gears out of alignment, destroying the crown wheel and pinion.
Price: $1700
Located in the eastern suburbs of Melbourne but I'm happy to freight any of the items, can package them up on a pallet for you and have them at a business address for freight pick up.
If someones buys the whole lot we can negotiate a good price, I will split items up if there's enough interest. I repeat this is a whole, quality 4AGE and T series conversion.
Bump
Bump
Bump price drop
Bump
Surprised that diff hasn't been snatched up considering its condition. Better then getting an unknown condition one from japan
pmd for difff
Hi mate the diff still available?
I've taken a deposit on the diff mate so see how we go.
