what I don't understand is why none of the serious tuners have fitted longer valves to the 20v engines. How about this: if 2mm longer valves where used then the buckets would sit 2mm further up. From here take 2mm off the base circle of the cams and then there is a new increase lift of the same amount without the height of the cam lobe being increased at all. The only real limit is the journal size which on a 20v is much smaller than the base circle size, so in short lots of material to use. Even the stock cams could be reground to have a harsh ramp rate with big lift.
