11400 RPM FUCK YEAH
congrats on finishing the build, this is gonna be insane
btw nice tiny motor ya got there hehe
hey guys,
just thought id share this with you, i just recently finished building my new engine from the ground up here are some specs
-7 rib block (new old stock from toyota)
-bigport head with major porting (was stripped acid bathed shot peened cracktested etc.)
- 3mm oversized TRD intake valves and 2mm oversize exhaust valves
-new valve guides
- TODA undershim bucket kit and valve springs
- TODA 304 deg intake and exhaust cams with 11.8mm lift
- TODA adjustable cam gears
- TODA Forged high comp pistons (with shaved head and .5mm TRD gasket its at about 12.1 : 1 CR
- ARGO 4140 Forged conrods
- GZE crank crack tested and X-rayed with 2.4 kg shaved, and balanced for 12,000rpm
- ACL race bearings
- TODA Chromolly flywheel and clutch
- TRD oil pump with a remote oil cooler
- Custom mandrel bent tuned length 4-1 headers to 2.5" collector (black heat wrapped)
- DCOE Weber 45 side draught carbies with anodized black trumpets
im sure there's a few things ive missed but anyway, engine made 224 flywheel hp at 11,400 RPM on the engine dyno
here are some pics after assembly
11400 RPM FUCK YEAH
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
yeh man! im stoked i finally finished it, it took me like 3 hours because mum wouldnt let me play until i'd finished dinner
epic.
simply epic.
did you find toyworld or toys r us had the better prices on adjustable camgears?
Nice specs.
Did Lego Garage do most the work?
I used to use them alot when I was younger.
Are you worried about the longevity of the engine, especially since you used such lightweight materials?
hahaha, mr fujiwara, r u secretly one of those lego pirates??
with the hat and little parrot aswell
SQ ENGINEERING
NCCE
Mine is 225hp.
that shit is dope, thought about cooling issues?
what gearbox will you be using? will a standard t50 be up to the task.
how did you fit vtec to the toyota engine?
hehe
