Results 1 to 4 of 4
Thread: 4ag engine list
    Member Aezion's Avatar
    Seb
    Default 4ag engine list
    its probley a common post but can anyone list all the different types of 4a*** engines with models & specs?? i know there is 16v 20v silvertop blacktops .etc
    but how many are there and what is the difference? im not exactly sure what is what.
    any info would be awesome
    google it:
    http://www.club4ag.com/faq_and_tech_...of%204A-GE.htm
    theres a better one that has a clear table and shows you the difference in compression, bore,stroke etc. im sure someone else will post it.
    Nathan
    Lilydale
    search google 'bill sherwood 4age' or 'phil bradshaw 4age'.
    All you will ever need to know to do with 4AGE.
    but a quick overview.
    - Rare and very early big port TVIS 16 valve, with black lettering & 6-bolts holding the flywheel on.(basically a 4AC with 4ag head and pistons to suit)
    - Big port TVIS RWD and FWD, 16 valve, blue letters on the cam covers, 40mm crank, 18mm gudgeon pin. 8 bolt 200mm flywheel.(most commonly seen engine, most AE82 and AE86) 9.5 comp?????(correct if wrong)
    - Big port TVIS FWD only, 16 valve, with red lettering. They have a seven-rib block, no oil squirters, 42mm crank, 18mm gudgeon pin. (AE82)
    - Small port non-TVIS FWD only, oil squirters, 10.3 comp ratio, 42mm crank 20mm gudgeon pin..(212mm flywheel) strong, but heavy rods.
    - Silvertop 20 valve. minor changes in VVT operation between earlier/later models, same rods and crank as late model GZE(strongest) 10.5 compression?. (212mm flywheel?)
    - Blacktop 20 valve, lighter internals compared to ST for revability, larger throttlebodies, smarter VVT. 11.0 compression.(212mm flywheel?)
    - Early model supercharged 4AGZE, low compression(8.0?) big port head, dizzy(225mm flywheel)
    - next model supercharged 4AGZE, big port head, higher compression, CAS Ignition(225mm flywheel)
    - Late model supercharged 4AGZE, high compression(8.9?) small port head, CAS ignition.(225mm flywheel)
    anyway, that should cover the basic development of the 4age
    Moderator Sam-Q's Avatar
    Endeavour Hills
    here you go:
    http://en.wikipedia.org/wiki/Toyota_A_engine
    I had to edit a shitload of it because there sure was some bullshit in there
  1. 4ag bigport engine etc
    By terryo in forum Car Parts For Sale
    Last Post: 9th September 2012, 10:56 PM
  2. Engine Parts 4ag jdm
    By cando1 in forum Car Parts For Sale
    Last Post: 19th August 2009, 07:20 PM
  3. WTD 4ag Engine
    By ae86trueno in forum Cars or Parts Wanted
    Last Post: 6th November 2007, 10:30 PM
  4. 4ag engine oil capacity
    By jdmcoupe in forum Technical - Questions
    Last Post: 5th October 2007, 11:01 PM
  5. various 4AG engine parts
    By terryo in forum Cars or Parts Wanted
    Last Post: 12th February 2007, 09:29 AM
