Results 1 to 2 of 2
Thread: Adaptronic Engine Manangment
    Davey & Riki-lee
    South Australia
    Seaford SA
    Default Adaptronic Engine Manangment
    R&D Mechanical are one of Adaptronic's South Australian dealers. We can supply, fit & re wire (full/custom engine looms).
    We have Adaptronic ECU's in our race cars and find them so easy to use and tune; Adaptronic grows with your car allowing future add ons etc.
    Recently we installed the new Adaptronic 440 universal Select ECU to a customers AE86 that we did a turbo conversion on. It had an old 80s Haltech ECU which was very hard to tune using a DOS type computer (very, very old). This ECU it only made 150kw with a T25 turbo, 264 cams, intercooler, exhaust and low boost. We made a brand new wiring loom using Adaptronic's 2.0M flying loom with the existing plugs (no cutting and soldering wires here, we dissembled each connector and did it properly). After completion we took it to the tuners and managed to get 170kw out of the little 4AGZE an extra 20kw from the Haltech!
    The Adaptronic ECU range has many features and are very tunable! Here are some of the products:
    Engine Manangment
    420D Select ECU
    • Compatible with most engine types
    • 4 ignition and 4 injector outputs, fully sequential operation
    • 7 or 8 auxiliary outputs with more control functions than you can point a stick at (eg 2 x closed loop VVT, boost control, idle control)
    • Launch control, antilag, flat shift and boost by gear all standard
    • Serial input for wideband O2 sensors (we recommend the MTXL)
    • Serial output for communication with dashes and dataloggers (we recommend the Race Technology units)
    • Inbuilt 4-bar MAP sensor
    • Headphone port for listening to the knock sensor while tuning
    • Basic closed loop ignition control
    • Closed loop fuel, idle, boost, 2 x variable valve timing control
    • Easy to use software
    • 4 programmable digital inputs
    • Dual maps
    Pricing: $990.00
    440 Universal Select ECU
    • Flex fuel function – fill it up with gas/petrol or any ethanol concentration
    • Adaptive fuel control (self tuning) – reduces dyno time
    • Traction control function
    • 8 programmable digital inputs
    • Dual maps
    Pricing: 1,399.00
    E1280S Fully Configurable ECU
    • “3D” Fuel and Ignition maps (as on any sophisticated aftermarket ECU)
    • Full 360 or 720 degree ignition or injection control (end of injection timing), unique to each output
    • 16 Analogue inputs (defaults are MAP, TPS, coolant temp, air temp, oxygen sensor, and spares)
    • 12 injector outputs – allows full sequential injection up to 12-cylinders, staged injection fully sequential up to 6 cylinders or full sequential primary and semi sequential secondary up to 8 cylinders. Spare injector outputs can be used as aux outputs.
    • 8 ignition outputs – allows coil-on-plug up to 8 cylinders, or 12 cylinders with external ignition multiplexing.
    • 8 configurable push/pull aux outputs, all PWM capable at arbitrary speeds
    • 8 configurable auxiliary digital inputs, with programmable pull high/low
    • USB PC interface
    • Field upgradeable firmware
    • Datalogging via ‘SEKUKU ‘ PC software, or to internal memory, or to a USB stick for virtually unlimited logging!
    SPECIAL FEATURES
    • Adaptive Closed-Loop Fuel Control – with configurable tolerances and loop gains, and conditions under which adaptive behavior takes place (requires a wideband oxygen sensor to be fitted)
    • Narrow-band (factory EGO sensor) closed loop fuel control
    • High current programmable outputs – allows direct drive of solenoid valves for boost control, air bypass etc
    • Special function programmable outputs – allows control of anti-pollution purge valves, air conditioners, fuel pumps, drive-by-wire, etc
    • Adaptive Closed-Loop Idle Control – allows configuration of increased idle bypass amount based on low battery, electrical load, air conditioner, as well as correction based on RPM, and optional closed-loop ignition timing adjustments for idle speed regulation
    • 5 crank/cam angle sensor inputs (for continuously Variable Valve Timing on up to 4 channels)
    • Open-Loop and Closed-Loop Boost Control
    • 4 wheel speed sensors, digital or reluctor (Traction Control and Launch Control)
    • Many other features
    Pricing: $1,990.00
    Accessories
    2.0m 420D/440 Select long bare loom
    Use this to make a brand new loom for your engine
    Pricing: $99.00
    0.5m 420D/440 Select short bare loom
    Use this to wire into your exsiting loom and make a 'patch' loom
    More at www.adaptronic.com.au or contact us for more information.
    Our introduction - Click here
    Senior Member 4.5AG's Avatar
    Vener
    NT
    Lyons
    pm'd
  1. Adaptronic price?
    By Ktas in forum Technical - Questions
    Last Post: 23rd April 2012, 10:33 PM
  2. WTB: Adaptronic
    By Drain in forum Cars or Parts Wanted
    Last Post: 14th July 2011, 12:46 PM
  3. Engine for sale, 4AGE, ITBS, ADAPTRONIC, Have a read
    By DRFTR86 in forum Car Parts For Sale
    Last Post: 7th February 2009, 09:44 PM
  4. Adaptronic
    By Cerby86 in forum Technical - Questions
    Last Post: 12th January 2009, 08:37 AM
  5. AdapTronic ECU
    By ke70dave in forum Technical - Questions
    Last Post: 13th November 2006, 12:14 PM
