Results 1 to 5 of 5
Thread: Hilux diff mounts
    Default Hilux diff mounts
    Where abouts in Sydney can i get my diff mounts swapped over from my stock diff onto my hilux diff?
    I was just going to take it to Diff Technics, but if people know of anywhere that have good experiance in this particular swap i'd rather take it there.
    Thanks people.
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    talk to ant from kaizen garage qld, im from sa and its cheaper and easier to get him to do it and send it down, also its exactly perfect fit dont even have to adjust panhard rod miint!!!
    AE86 THE BEST
    bit off topic, but close enough, are there any other changes needed to a hilux diff to get it to fit or just mounts?
    Senior Member Rip it's Avatar
    Jake
    If you have to ask this question I wouldn't suggest you try it alone. 4 Link Mounts are a start, then sway bar and shock mounts, stud pattern change, rear brake set up, brake lines, hand brake set up and tail shaft.
    I got nothing.
    yeah I havnt done much research into this, just thought i'd ask since i was in close enough to the right spot. think i'll just weld the ke diff and see how long that lasts
  1. Replies: 0
    Last Post: 1st July 2012, 01:36 PM
  2. Hilux Diff
    By wideslider in forum Car Parts For Sale
    Last Post: 27th May 2010, 08:36 PM
  3. hilux diff
    By rolla92 in forum Technical - Questions
    Last Post: 22nd June 2009, 06:59 PM
  4. hilux diff
    By DRF17 in forum Car Parts For Sale
    Last Post: 13th June 2009, 10:22 PM
  5. hilux diff
    By Fozz in forum Technical - Questions
    Last Post: 4th June 2009, 10:08 PM
