Ha Ha I just stumbled across this yesterday, your right its much easier to handle.
Does it leave the surface ok to prime? as in, is there sufficient key for the primer to adhere to?
Just white again. Going to keep all interior white and do exterior that light blue.
Ha ha, yeah vtec is the only one with a red car now, other jase's is metallic grey, mine will be light blue. It will be a mix up of colours
Needs moar skids
light blue PASTEL? do it (like, non metallic)
Yeah no metallic. And fuck oath it needs more skids, it's been skidless since Jan.
Here's what I'm up to
Engine is getting there, my engine builder treated me to some new sump bolts and shiney stainless Steele welsh plugs. Good enough is not good enough for this guy, he spent a whole night panel beating out the dings in the sump.
Just have to finish porting the head (about another 2 days work he recons). Then bolt the head to block, bolt down cams, do valve shim clearances, put on all belts on. Then slap the bitch back into the freshly painted engine bay.
The shit weather has really been holding me up, as you can see by the small river that has formed under my car.
