Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 40
Thread: dangdangs jzz30 project
  1. #11
    Veteran drift kid's Avatar
    Glossodia
    Very fancy
  2. #12
    Senior Member dangdang's Avatar
    Aug 2010
    Danga
    Tas
    Aus
    Gearbox time.
    Got hold of a jzx100 r154 which was stuck in fourth gear, pulled it down to find a stretched and broken fourth gear synchro ring and hub.
    Next....got hold of what was a brand new jzx100 box with a stripped third gear, which was used in a mates car for one drift round before he converted to a sequential dog box.
    Add a pair of Marlin Crawler billet shift forks, a full face thrust washer and a billet centre plate and I should be able to make something work...for a time...
  3. #13
    Aug 2010
    Danga
    Tas
    Aus
    Box back together with new 3-4 hub selector, all synchros and bearings replaced.
  4. #14
    Aug 2010
    Danga
    Tas
    Aus
    Swapped a rear sump onto the donk in place of the Aristo front, added a new genuine Timing belt and tensioner a billet tensioner bracket, new water pump, Ross Metal Jacket harmonic balancer, 1zzfe COP coils, replaced the broken VVTI solenoid (yet to see one not broken when engines are brought in as they stick out so far) replaced the brittle old cam cover breather hoses and painted the cam covers.
  5. #15
    Aug 2010
    Danga
    Tas
    Aus
    Lathed down some tube nuts to attach the Chooka engine mounts to the factory engine block to mount pedestal as the whole lot is being moved back 50mm.
    This kills several birds with one stone, weight shifted back, jzx100 shifter is right in the trans tunnel hole, the 50mm shorter auto tailshaft will fit and there is now jags of room in front of the engine.
  6. #16
    Aug 2010
    Danga
    Tas
    Aus
  7. #17
    Aug 2010
    Danga
    Tas
    Aus
    Offset engine mount time
  8. #18
    Aug 2010
    Danga
    Tas
    Aus
    Notched the rear crossmember just a tad to clear the sump.
    Clearanced the trans tunnel up 20mm with a steel dolly and rubber mallet just to clear the top of the jzx100 remote shifter.
    Then started sussing out turbo and manifold position.
  9. #19
    Aug 2010
    Danga
    Tas
    Aus
    Mazworxs manifold CNC'd manifold flange, nice thing, 1/2 inch thick plate milled just enough to clear the millscale, steps from the oval exhaust port shape, offset for stud clearance and rebated for 32mm nominal bore steam pipe.
    Collectors.
  10. #20
    Aug 2010
    Danga
    Tas
    Aus
    Going for a low mount, equalish length, well spaced and keep enough room to sneak some twin plumbed back gates and a 4" dump.
  1. dangdangs 2jzge>1jzgte st141 Rona Wags
    By dangdang in forum Other Toyotas
    Last Post: 2nd December 2013, 11:40 PM
  2. JZZ30 Rolling shell. Needs to go ASAP.
    By happysumo in forum Cars for Sale (Toyota Only)
    Last Post: 1st January 2013, 03:52 PM
  3. (syd) custom jzz30 soarer
    By Dexter in forum Cars for Sale (Toyota Only)
    Last Post: 31st July 2012, 02:42 PM
  4. 91' Toyota Soarer Jzz30
    By Captiain_Fantastic in forum Cars for Sale (Toyota Only)
    Last Post: 6th November 2011, 04:29 PM
  5. F/S 1993 Toyota Soarer JZZ30
    By Megz in forum Cars for Sale (Toyota Only)
    Last Post: 23rd February 2010, 03:34 PM
