S14!? Hmmm...is that a direct bolt up? I met a guy off of the 3tcgarage board that said that the MKIII MC worked on his car, but that's on a TE37.
does neone know the size of ma61 brakes? cause there 4x114.3 arent they?
bought a hatchi from daylesford..
...spiders...everywhere...
258mm x 20mm vented
BENT MECHANIX - Garage 20:
280mm
So what are you doing abou your clutch master? Hmmm....you guys set up over there is RHD. I wonder if I use a S14 setup from here in the states if it would also bolt up since their both LHD.
you just need to remove it to get the brake master in, then you put the clutch master back in. the finished product is in the pic
Judging from the picture the S14 looks very similar to my R32. Couldn't tell for sure but are they the same? Might be worth looking into for people have troubles finding a 32 cylinder.
I got nothing.
not sure if its the same...
also more chance of being in better condition.....
confirming which brake master i need, i think its this one...
can anyone confirm this is the right one?
The Bore Size of this unit is 23.81mm (15/16")
