Results 1 to 10 of 12
Thread: LS2 KE70 RACECAR
    Billy
    Tarragindi
    Default LS2 KE70 RACECAR
    Hi guys,
    Here is my ke70 you have probably seen it before but not like this . Just so you know it did have a to4z on it but decided against it lol it was just an idea. Will be na with 8 stack and big cam eventually.
    Engine
    LS2 6 litre
    exhaust
    None as yet but will be twin side pipes
    Suspension
    Brakes/Suspension
    Front-Custom made front coil overs with 8kg swift springs and kyb agx 4 way adjustable shocks, Ajps front sway bar, T3 camber tops and custom strut brace, Ae86 power steering arms, Sigma lower control arms and t3 RCA’s. Jdm vented rotors with braided break lines.
    Rear- Custom made coil over’s using 6kg springs and kyb agx 8 way adjustable shocks and a T3 rose jointed adjustable pan hard rod. Rear Ajps Sway bar and Ajps traction brackets, Nolothane bushes throughout car. s13 rear disks.
    15 by 9 -10 rotas . Sorry everyone just rather spend 6 grand on parts then two sets of good wheels:
    Equal Length adjustable 4 link rear, 16 point cage, custom steering column, bride low max fixed back, nardi deep corn wheel,custom dash, custom wiring. custom everything .
    I am considering getting some 16 inch te37s later on to get more grip but will just get it going first
ID:	30907   Click image for larger version.
ID:	30908   Click image for larger version.
ID:	30909   Click image for larger version.
ID:	30910   Click image for larger version.
ID:	30912   Click image for larger version.
ID:	30913   Click image for larger version.
ID:	30914   Click image for larger version.
    Veteran skizzamods's Avatar
    Oscar
    Adelaide Hills
    I would suggest something more along the line of rx7 brakes and some good pads over the JDM set up.
    ae86 brakes will really be too small for this..
    Billy
    Tarragindi
    im going a willwood big brake kit when I have coin...... but it will do for now I don't really use foot brake to much drifting anyway but its defs on the to do list
    Need more engine bay pics
    Veteran johl's Avatar
    Johl
    looks great.
    16's are a great idea. especially with how many tyres you will burn through. a few guys i know changed from 14/15's to 16 just for the cheap 16 inch tyres
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Show us the video of you skidding that industrial
    #bushfire
    Veteran drift kid's Avatar
    Glossodia
    Thing looks menacing, good work, will be awesome to drive
    Senior Member Flush-on-15s's Avatar
    May 2013
    dylan
    Echuca
    holey hell this... is... amazing man... so tough
    Have a Look at my ae71 streeter build thread!
    http://www.ae86drivingclub.com.au/fo...s-Clean-Spirit
    Quote Originally Posted by timbo View Post
    This is like reading the Women's Weekly.
    Jan 2013
    Martin
    Berlin
    Prenzlauer Berg
    Germany
    Hello which fender flares use you on your Ke70?and how wide is the flare?:-)
    The car looks great
    Mar 2011
    Ali
    Daaaaaaaaaaamn!
  1. Replies: 4
    Last Post: 19th December 2012, 08:12 PM
Tags for this Thread
