Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 33
Thread: Patrick's MA61
  1. #21
    Aug 2010
    Adrian
    South
    I did a SOR for my 4age ke70 a couple of years ago, they wanted a rigidity test along with other tests, so I would imagine they would want them from this
    Oh and my conversion was done with all ae71/86 parts
  2. #22
    Mar 2013
    Patrick
    South Australia
    Mount Barker
    i spoke to David the head of the standards people with reference to my existing 7MGE SOR, he said it would mostly be the same for 7MGTE as its already a capacity change and +30% power increase, possibly with a lane change test, and less likely with a brake test depending on the updated list of brake mods and supporting mods on the new MR620. Both I would be reluctant but fine to do (they'll be easy to pass anyway). He said nothing about chassis rigidity and hopefully he never does haha
    The engineers i spoke to said that should I need a chassis test they would be surprised if it failed as stock....thats nice but I'm not super confident ill pass without extra bracing, seam welding, or whatever else.
    Did you end up actually doing the test on the KE70? Howd you go?
  3. #23
    Site Supporter Javal's Avatar
    Josho
    I was speaking with Josh Smith from Autest about the torsional rigidity testing and he said it's usually big old yank cars that fail. He showed me the process on a car which was going through engineering at the time, a 1GGZE RT132 Corona - you might have seen it at AJD - which are definitely not the stiffest cars to leave the toyota stable, 5 doors hatchback, long body, chassis rails that stop in the middle section (like xE7x / AE86) etc etc, and it passed with extremely easily. Higher grade steel was mentioned. MA61 has fewer open areas (i.e. no rear doors) and thicker pillars, so I wouldn't stress about it too much.
  4. #24
    Aug 2010
    Adrian
    South
    No I didnt go ahead with the process, didnt seem worthwhile for my particular car
  5. #25
    Mar 2013
    Patrick
    South Australia
    Mount Barker
    Time for an update.
    7MGTE was approved in October and then revised again in December. I'll need Nissan 4 pot brakes and 296mm rotors, an idle speed emissions test, and a regency roadworthiness inspection (same as the one to clear a defect).
    Just this week I bought an engine, it came out of an MA61 too so it will be very easy work. I think it might be a complete MA70 Turbo A engine, but it at least has the Turbo A intake and the ECU.
  6. #26
    Mar 2013
    Patrick
    South Australia
    Mount Barker
    Look what came in the post!
  7. #27
    Mar 2013
    Patrick
    South Australia
    Mount Barker
    Also, R33 GTST brake upgrade!
  8. #28
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Have you consulted with a chartered engineer also along the way, or just submitted the application of modification?
    There is a 4agze ae86 around Adelaide registered which has been engineered.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  9. #29
    Mar 2013
    Patrick
    South Australia
    Mount Barker
    I've spoken 5 or 6 different engineers pre-MR620 and all of them just had hypothetical suggestions. The most helpful person to speak to was David Gunnar at DPTI. In the end after submitting 2 MR620s my Statement Of Requirements didn't stipulate that a chartered engineer look over anything! So I am starting to dislike the term engineered as it's almost meaningless. I can get this 7MGTE and the brakes and a few other things in the car and onto the rego papers without actually paying a chartered engineer a cent...but it's still called engineering lol
    EDIT: I have however been using Martyn Adams (MDA Motorcycle Engineering) in Mt Barker for my custom work, like the mods to the hubs/rotors to get the R33 brakes to fit. He's got a great eye for detail and accuracy. I'd recommend him to anyone for literally anything.
  10. #30
    Marco
    Ok good to know. I was wondering whether you had spoken with Tonkin consulting, Rory Thompson or Doug Potts. All good. Will be great once you have it on the road. Great work!
  1. Clays MA61
    By ke_70 in forum Other Toyotas
    Last Post: 29th January 2012, 01:01 AM
  2. Ma61
    By shift_rook in forum Cars for Sale (Toyota Only)
    Last Post: 31st July 2011, 07:18 PM
  3. Ma61's
    By Roollla.83 in forum Car Parts For Sale
    Last Post: 3rd March 2009, 10:38 AM
  4. MA61's
    By Adash =P in forum Car Parts For Sale
    Last Post: 31st January 2009, 04:53 PM
  5. ma61 rims please
    By HiLtOn in forum Cars or Parts Wanted
    Last Post: 9th April 2007, 07:32 PM
Tags for this Thread
