The ae86 has an efi relay in it, so all u need to do is trace the pins at the bottom and use the power off that.
Are you running a thermo fan or the engine fan off the water pump?
Hey guys,
Pretty much as the title says, I'm in the middle of putting a 16v bigport into my sprinter and was wondering which is the best fuse box to use?
I am using an AE82 loom that I have wired an adapronic into, as far as the engine goes it's all wired up but as for battery terminals, fuse box and cluster wiring goes I haven't yet decided and was hoping someone with experience in this conversion could give me some input.
Great, I will use the 4AC fusebox then and just wire in the EFI relay, I already have a thermo fan setup on my 4AC and it is wired to an external fuse, I hope there is room in the inside the 4AC fusebox for a extra relay, I prefer the cleaner OEM look
