Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: TE72's (T18) found on a farm
  1. #21
    Senior Member AIROCOBRA's Avatar
    Bob
    ACT
    Weston
    Thanks for that Paul, I have done the panel and paint with the mind that I may not put the mouldings on . The car is mainly for the wife to have a ( race car ?) for motorkhana's and khanacross.It will be on historic plates so not going to see to many car parks. Just a fun weekend car for the beloved to play with. That way I can earn brownie points to spend more on the Sprinter ( I wish ! )
    ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
    AE86 4AGE 16V N/A TRACK CAR ( RED )
    AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
    AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
    AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
    AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
    KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
    TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
    Soarer 1995 1JZ Factory 5speed (R154 )
  2. #22
    Bob
    ACT
    Weston
    They always look better in the light of day , not much more progress , crap weather and the Easter happens !
  3. #23
    Bob
    ACT
    Weston
    Been a while since I have up dated , other projects have slowed things a bit , but there has been some progress . A change of mind in regard to the T18 usage has seen the need to do a few more items . No longer a weekend historic , she now is to be a daily. So gearbox out , change the old 3.7 std rear ( witch noisey ) to a 4.1 AE86 T SERIES drum set up. And engine out to fix the brake fluid paint damage on the firewall. But during this process a few alarming things where found with regard to previous mechanical workmanship.
    --- while taking out the gearbox , the noisy thrust bearing fell out ( hit me in the face ) No retaining clips where installed so the thrust bearing could never release with clutch fork. ( no wonder one side was a wee bit worn.
    ---after pulling the engine out found that no gasket or sealant was used on the heads rear inspection plate . ( metal to metal seal -- bit of a leak ? )
    --- clutch installed wth many different tensile rated bolts , including a Bunnings alloy bolt ???????????
    --- front pinon seal was incorrect and most of the oil had leaked out -- probably why the diff was a tab growlie.
    --- engine mounts had been installed up side down , they modded them to do it ?????????
    --- bottom of radiator tank rusted away so PVC drain pipe glued to tank and hose over the top ( it actually was sealing ) but for how long ????????
    but other than that she is all good , few more repairs and parts to be replacemented ( like all new steering bits, cluth cylinder , brake master, etc etc etc and we can start the reassembly.
    And out she comes
    185 PSI in all pots (cold) and by the look of the head the recent engine rebuild was done properly.
    Bugger it , since I am going to rust proof and paint under the car , I suppose I may as well pull out the cross member and paint it .
  4. #24
    Veteran stahlz_ae86's Avatar
    Paul
    If the crossmember comes out, you may as well mod a KE one to take T mounts and do r&p swap
  5. #25
    Bob
    ACT
    Weston
    Not for the moment , gunna keep the old girl std , score a reco steering box and all steering arms ,ball joints etc etc on the cheap , so steering will be like new . Plus thius way no rego dramas as well.
  6. #26
    Bob
    ACT
    Weston
    Bloody weather has been crap lately, some days not getting above 5 degrees. But still managed a bit of progress.
  7. #27
    Bob
    ACT
    Weston
    Another step in the right direction . engine , gearbox and rear end all back in and engine has been blinged . The beloved wanted a bit of wow in the engine bay , but no preformance mods. Not quite my cup of tea , but she is ex-static about the changes and that's the most important bit . HAPPY WIFE IS A HAPPY LIFE !!!!!
  8. #28
    Bob
    ACT
    Weston
    And then I got a bit more done -----------
    Refirbished and replacement everything
    sway bars fitted
    one blinged front end
    fuel tank and bits fitted
  9. #29
    Veteran AJPS's Avatar
    Lonsdale
    i see red, i see red, i see red
  1. Toyota T18 TE72
    By the_sleepa in forum Cars for Sale (Toyota Only)
    Last Post: 18th August 2010, 10:31 PM
  2. T18/te72
    By jakel in forum Cars for Sale (Toyota Only)
    Last Post: 19th July 2010, 08:38 PM
  3. t18 brand new rear quarter found at wreckers
    By ke70dave in forum Brisbane & QLD Events and Discussion
    Last Post: 21st July 2009, 10:44 PM
  4. Te72 t18
    By TrdHowie in forum KE70 / AE71 Owners Forums
    Last Post: 14th January 2009, 08:58 PM
  5. My first TE72 T18
    By us_ae86 in forum KE70 / AE71 Owners Forums
    Last Post: 17th February 2008, 08:59 PM
