Results 1 to 9 of 9
Thread: Wat LSD goes into a F series Tarago diff?
    Senior Member Dongaz's Avatar
    Cameron
    The Gap, Brisbane
    Default Wat LSD goes into a F series Tarago diff?
    What LSD's can you use and is there any modifications that need to be done for them to fit?
    Part numbers and cars they come in would be awesome.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I was going to tell you to go search because its been covered plenty of times before, but unfortunately the search function on this site will not search "lsd" as its too short a term.
    It has been covered over and over but your options are:
    MA61
    IS200
    Those two cars came with factory LSD's, some 4WD hilux's may have came with LSD's in the front diff (which is usually an F-series).
    There is a huge list of other places which make aftermarket units including:
    TRD
    Truetrac
    KAAZ
    Get out there on the internet and search, there are all sorts of different types of LSD's in 1 way, 1.5 way & 2 way variations as F-series diffs are in so many different types of Toyotas.
    And as far as I am aware they are interchangeable between any other F-series setup.
    Ok
    Seamus
    Milton
    I spent a while working all this shit out and writing it all up, if it doesn't help you i don't know what will...
    Any LSD that suits:
    SXE10 Altezza (RS200) - 98+ (3SGE)
    GXE10 Altezza (IS200) - 98+ (1GFE)
    TA63 Carina - 82-85 (3T-GTE)
    RA63 Carina - 81-82 (18R-GE)
    GA61 CelicaXX - 81-86 (1G-GE)
    MA61 CelicaXX - 81-86 (5M-GE)
    MA63 CelicaXX - 81-86 (M-TE)
    TA64 Celica 82-83 (4T-GTE)
    TA63 Celica 82-85 (3S-GTE)
    RA63 Celica 81-82 (18R-GE)
    AA63 Celica 83-85 (4A-GE)
    TT142 Corona 82-87 (3T-GTE)
    RT141 Corona 82 (18R-GE)
    GS130 Crown 87-99 (1G-GE, 1G-GP)
    GS131 Crown 87-88 (1G-GE, 1G-FE)
    GS131 Crown 88-95 (1G-GE, 1G-FE)
    YM130/MS130/LS130/LS131 Crown 87-99 (M-P, 3Y-P, 2L, 2L-T, 2L-TE)
    JZS130 Crown 90-99 (1JZ-GE)
    GS141 Crown 91-95 (1G-GE)
    LS141 Crown 91-95 (2L-TE)
    JZS171 Crown 99+ (1JZ-FSE)* Only Auto Version
    GRX125 Mark X 04+ (4GR-FSE)
    GZ10 Soarer 81-85 (1G-GE)
    MZ10 Soarer 81-85 (MT-E)
    MZ11 Soarer 81-85 (5M-GE)
    MZ12 Soarer 85 (6M-GE)
    GZ20 Soarer 86-89 (1G-GE)
    GZ20 Soarer 89-91 (1G-FE)
    GA70 Supra 86-88 (1G-GE)
    GA70 Supra 88-90 (1G-FE)
    TRD Part # 41301-RA010......(2-way)
    KAAZ Part # SAT2090......(2-way)
    CUSCO Type RS (MZ not available for this diff) Part # LSD 150 F......(1-way)
    CUSCO Type RS (MZ not available for this diff) Part # LSD 150 L15......(1.5-way)
    CuSCO Type RS (MZ not available for this diff) Part # LSD 150 F2......(2-way)
    TOMEI T-TRAX ADVANCE Part # 562043, Part # also referred to as "TFA" on some sites......(2-way)
    The CUSCO LSD is most expensive, followed closely by the TOMEI lsd. KAAZ is a hundred or so cheaper, and the TRD is the cheapest by another hundred or so.
    Kieran
    there is currently a group buy for the truetrac torsen centres from the US on toymods and are fairly cheap for new items
    Lawrence
    Wollongong
    That is an impressive list I must say, good work with that
    Anthony
    What is it with toymods and truetrac? Id def go with a clutch type LSD.
    Ok
    Seamus
    Milton
    Agreed. I guess it's okay if you only take it to the gay long black strip
    Otherwise yeah, bit ghey. Clutch lsd wins
    Cameron
    The Gap, Brisbane
    I knew there were a few to choose from but I wasnt to sure which std LSD's fit directly in. I thought I read somewhere that with the IS200 LSD it needed a shim or something machined up to space the centre...not really to sure.
    So if it's from an F it will fit into an F with no dramas?
    Senior Member xsoarerx's Avatar
    Logan City
    theres some funny bisness between the SXE10 and an 80's F serise but japlish sorted it but grinding down the half shafts to fit in better.
    MA61 LSD's are shiet! very weak and most are rooted, you need to get them rebuilt... dont last long behind 1jz's but i guess behind a NA 4a youll be fine... but if you got a stock 4a i wouldnt see the point of getting an F serise.
    who know's, my supra had one before i got it (we swaped rear ends cuz he wanted to keep it) and it wasnt too bad on the street but it wouldnt be good for sliding at all.
  1. Tarago YR22 Diff > Altezza LSD fit with no mod's?
    By cam_123 in forum Technical - Questions
    Last Post: 2nd May 2011, 02:58 PM
  2. Tarago Diff- F Series 4.3 ratio
    By Cerby86 in forum Car Parts For Sale
    Last Post: 12th November 2010, 04:27 PM
  3. What is a YR22 Tarago F-Series Diff worth?
    By Golberg in forum General Topics (No Technical Questions)
    Last Post: 27th May 2009, 11:46 AM
  4. F-Series Tarago Diff Models and Years?
    By lloydious86 in forum Technical - Questions
    Last Post: 24th May 2009, 11:11 PM
  5. yr22 f series tarago diff lsd's
    Last Post: 27th May 2008, 09:03 PM
