Nice! Just got my jzx73 running this week, awesome daily
picked this up today for 300 bucks, needs paint job and new fuel tank (full of rust). 180,000kms, 2 owners, pretty much complete service history, new auto in 99, pretty tidy inside, power windows and mirrors.
picked this up a few weeks ago cheep as chips
and its fitted with this
so i already have a good, fast, comfortable, very capable 4x4 and the surf would be fair bit of work to get back to roady/ok condition. so the 1uz is going to find its way into the cressida for some driftage.
plans for cressy:
respray (toying with doing same color up top and going a dark blue two tone?)
rego
1uz and r series gearbox thanks to adapter already in surf (maybe even aftermarket ecu, adaptronic?)
big brakes
modplate
coil overs from my rt142
camber adjustable rear subframe also from my rt142
weld diff or lsd of sorts
Tell us more about your fast and capable 4x4, im intrigued!
Rt142 subframe wont bolt in as they are narrower then mx73 ive been told
ahh yes i measured the differences today, wider buy about 40 mm or so, i knew they were wider but i thought the difference was in the lower arms cause some of the pics i seen where they had changed the outer lower arm mount in a mx73 it was a bit further away from the sill than in my rt142, just gonna have to cut the mounts off and weld them on this subframe i suppose.
done some rust repairs, not sure if this is the "correct" way to do it but seemed the most logical to me haha
photos are of different sides of the boot
also the 4x4 is a 92 80 series factory turbo 1hdt. high flowed turbo from GTurbo (very highly reccomend), intercooler and 3" exhaust at made 195hp at all 4 wheels (constant 4wd) and just shy of 600nm with 24psi boost, dream to tow with, overtaking trucks like nothing towing the cressy home hehe. 3ish inch lift, 33 muddies, front and rear lockers, swing away wheel carrier, photo is from when we went to cape year before last (note ajps sticker hehe)
a few more random pics at
Nice! what sort of economy does it get?
cruising normal around 14-14.5L/100, towing around 18 ish, haven't had a good chance to test economy towing much. used to be better before the power tune, and after reading some stuff on the net and talking to a few shops and the bloke i got the turbo through, the tuner who i used isnt the best for economy apparently, he dose more race tuning and full noise stuff that the average idiot like me haha, according to the internet (never lies) with all new stuff like i have (injectors and pump) and a good tune i should get 12-13 ish even with the accessory (lift, tyres, bullbar ect) and still have much the same total output, dosent worry me too much at the moment but might get it re-done somewhere else or have a crack myself if im feeling keen haha
20mm each side for subframe.
I'd suggest doing solid raisers too.
Hey Macca,
Welcome to Cressida club !
$300 is the best price I've ever heard of ! I paid $500 for mine with 155,000km, had it for 5yrs now.
If you want to cut down on the body roll cheaply, you can add another factory rear sway bar, the mounting bolts
on the suspension are long enough to fit thru them both.
Then you simply add 2x 20mm ubolts near the factory clamps to hold the centre in place. Instant 20mm sway bar !
I've had mine for 4yrs now and it's made a huge difference to my cornering fun
How much did you pay for the 1UZ Surf ?
Koreisha Racing Team
solid raisers like.. the rear subframe-chassis bushes? i have super pros in my rona and they seem pretty good i think so might just go them again once i have her on the road.
yeah going to look at another one today for straight panels but might turn out to be in better condition that this original one.... so yeah i was thinking about double sway bar.
the surf was 1500, so in my eyes thats pretty good for a engine, loom, computer (which i might ditch and run aftermarket yet anyway) and r series gearbox adapter and clutch ect, apparently engine has only been in there for like 2000kms, and i can sell the body off once im done for a few bucks hopefully
got some primer on today, some parts are a bit dodgy, gonna have to touch them up, but i just wanted to get some primer on cause it may be a week or so before i get to touch it again.
anyone like to make suggestions for paint schemes/colors? im thinking 2 tone or some sort, trying to use the blue that it was origionaly as one of the colors so i dont feel so guilty for not doing the door jams haha
