Results 1 to 10 of 12
Thread: Shortening Bumpers?
    Senior Member GOODY's Avatar
    Logan
    Default Shortening Bumpers?
    I've seen a couple of ke70's/ae71's on here that have had it done but I'm not totally sure how to do it with the result turning out neat and tidy..??
    Anyone got a guide on what to do exactly?
    theres one on the old forum>>>does search still work
    Senior Member addikt's Avatar
    Tyson
    i wana know this also i dont get it
    Old username : hally
    Beige build in the works!!
    http://www.ae86drivingclub.com.au/fo...426#post874426
    Senior Member sly1300's Avatar
    Dan
    NorthEast
    nah, that guy chopped em back a little too far.
    no wraparound bits.
    anyone got a link for the other bumper chop? was a little less drastic and didnt have to chop mounts or anything, was basically just a plastic trim...
    i remember reading it but cant remember where.
    oh hang on this isnt /r/ lol
    from my old ae71 thread on the previous dc forum, might help u guys out:
    "ok ive been asked quite a few times about how to do the bumper trick. so to save people asking me, this is how i did it:
    first i took the bumpers off the car. i undid the bolts that you can find in the engine bay and also the ones in the boot.
    next i separated the black plastic from the metal supports. there are lots of little tabs u can see when looking at the reverse side of the bumpers, which hold them onto the metal. just twist them off or whatever u need to do to get the plastic off.
    then i got rid of the metal supports because you cant use them with the trimmed down bumpers.
    once the black plastic was separated i had a look at them, lined them up on car, then decided how much to trim off. on the rear u need to get rid of the numberplate light. so i used that as a guide as to how much to cut off. on the front i just guessed how much i wanted to cut off. i had to rush the front so i think i cut too much off it. ended up a bit thinner than i wanted it to be, but oh well
    i just used a jigsaw to trim the bumpers down to size. pretty quick and easy to use.
    once i trimmed them to size i drilled some small holes in the body and also in the bumpers, then used cable ties to hold the bumpers on. i also used cable ties to hold the front indicators on.
    dont rush it, and remember u can always cut off more, you cant put more plastic on if u cut too much off
    and just be aware that once u do this the bumpers have almost no function if u run into something. but its a cheap and easy way to get rid of the standard park benches.
    i got the idea from gilly's old ke70 so dont give me the credit for the idea. here's a couple of pics of his old car that i used to get an idea of how much to cut off:
    good luck "
    and a link to the thread:
    http://www.ae86drivingclub.com.au/bo...ic=4516&st=150
    - andrew
    Tyson
    it would look pretty wak and rough up close ay?
    Junior Member Killswitch's Avatar
    So, you remove the best foot stool/beer holder ever made by any car manufacturer and repalce it with a totally aesthetic weak thing that means you can't dent your mates geminis for fear of busting your car.
    Whats the point!
    edit: the one on ke70.com is pretty decent though
    Logan
    Thanks for the help guys, still deciding whether I will go ahead with it or not yet.
    性交を愛する
    Do it.
  1. shortening 4 runner diff
    By RhysE in forum Technical - Questions
    Last Post: 28th June 2012, 11:22 AM
  2. Throttle Cable Shortening; Soldered Vs Solderless Nipples
    By GeeEss in forum Technical - Questions
    Last Post: 27th October 2011, 07:25 AM
  3. Help! Diff re mounting and axel shortening
    By baumyone in forum Adelaide & SA Events and Discussion
    Last Post: 1st February 2011, 01:19 PM
  4. Shortening handbrake
    By _matt in forum Technical - Questions
    Last Post: 29th July 2008, 07:07 PM
