looks like its going to be a grate build! very much the same thing i want to do to my celica.
keen for updates keep up the good work. ^_^
Time to EDIT this! LOL
Hi All,
This is my ST141 Corona i bought off a family friend about 8 month ago, track/weekend car.
Motor
450rwkw 3sge beams (gen 5)
Carrillo H-Beam rods
Toda 285/280 cams
Toda 8.5:1 forged pistons
Toda metal headgasket
Toda valve springs
Custom sheetmetal intake manifold
70mm billet throttle body
Custom exhaust manifold
Borg Warner EFR 8374
MRP oil sandwich plate with thermostat
Custom twin entry fuel rail
1800cc injectors
ECU
Emtron KV8
Gearbox
6 Speed sequential
Direct Clutch Services custom clutch
Diff
Unknown, maybe hilux or an irs conversion
Brakes & Suspension
Wilwood 4 pistons calipers (front)
Winmax race pads
Brembo 280mm discs
BC gold coilovers front
BC gold adjustable springs & shocks rear
AJPS rosejointed lower control arms
AJPS extended tie rods
AJPS 50mm RCA's
AJPS lock spacer
Interior
Bride Lowmax bucket seats
Custom seat rails & mounting positions
Takada harness'
Nardi steering wheel
Digital dash
ASD hydraulic handbrake
Fuel
E85
Walbro intank 460lph feed pump
Aftermarket Industries surge tank with 2 x Walbro 460lph pumps
Wheels
Riverside R101
Front 14x7-3
Rear 14x7-3 but will be cut up and widened once diff is decided!
Possibly 14x8 or 14x8.5-20 something!
goodluck! looks like a sweet base
Nice car mate.
What you doing with the standard borgy diff?
Michael
Im just going to weld it up for now.
Later on will probably put a f series in with a 4.7 ratio.
Looks like it's going to be a weapon of a car, some decent coin going it's way, keep it up
Should be good son!
Those Borgy's are shithouse, will be good for the wet though. You should destroy it in no time with that beams, or an axle at least lol!
loving the sun shade!!
