Results 1 to 7 of 7
Thread: ke70 with ca18det wiring... help!!!!!!
    May 2013
    rikky
    gosnells
    Default ke70 with ca18det wiring... help!!!!!!
    just wondering if anyone in perth can help me or point me in the rite direction.
    i have no idea with wiring and dont want to give it to a so called sparky thats going to spend 40+ hours
    on doing it charging 50 dollars an hour.
    i have read up a bit on it and seems to me for someone that knows what there doing 10 hours work would be more than enough.
    any help would be really appreciated
    Member gaspal's Avatar
    Richard
    Osborne Park
    Ive done SR20 in ae86 last year, only a few wires to hook up like ignitions, grounds and batt pos. ill see if i can dig out which ones you need but its pretty well documented on the net, take the time to do a good search. Its pretty much run the CA18 loom down the passenger side of the engine bay to the fuse box and get almost everything you need from there...
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    This is SR20 stuff, but I doubt that the CA18 is THAT much different when it comes to wiring...
    There are actually very few things the engine itself needs from the body as far as wiring goes (other than the Nissan ECU that you will already have I guess)
    Have a read through this website:
    Current Cars:
    May 2013
    rikky
    gosnells
    thanks guys. the more help the better haha.
    May 2013
    rikky
    gosnells
    this wire up dosnt make sense, isnt a relay ment to have a ground source?
    on the fuel pump and afm / cas it looks to be all power?
    Is that rite??
    Veteran Nikkojoe's Avatar
    Tom
    One would say the relays ground via the ecu (well fuel pump and the afm/cas relay).
    Veteran Skylar's Avatar
    Ken
    I'm a little late to the party, but that's how the Nissan side is wired from factory. All I did was show the Nissan side and Toyota side together so people would know what to do. If you follow it, the car will fire up, as long as you find the correct wires (there's are multiple same colour wires from memory).
    You can just pull the three relays and wiring out of a s13 engine bay harness and fuse box and just hook up the white and black/orange wires from the Toyota side. I tucked mine up in the passenger's side wheel well along with the factory ke70 fusebox.
    What's easier and nicer is to ditch the factory power system and ECU and make a fuse panel and get a vipec/link/haltech/adaptronic.
  1. CA18DET into KE70 dilemma
    By foamy in forum Technical - Questions
    Last Post: 25th October 2011, 08:17 AM
  2. Ke70-ca18det speedo
    By wagoooon in forum Technical - Questions
    Last Post: 16th October 2011, 04:48 PM
  3. Ke70 ca18det
    By Hektic323 in forum Cars for Sale (Toyota Only)
    Last Post: 5th February 2009, 10:05 PM
  4. ca18det t28 turbo and ca18det manifold siut t3 t4
    By joshnz in forum Car Parts For Sale
    Last Post: 18th December 2007, 07:47 PM
