Results 1 to 10 of 17
Thread: 16V to quad throttle manifolds- in aluminium / carbon fiber
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Default 16V to quad throttle manifolds- in aluminium / carbon fiber
    16V 4age to quad throttle manifold
    Thought I would give people a bit of an advanced notice on what I might be able to offer soon enough.
    These are manifolds to bolt 20V silvertop quad throttles on to a 16V, with both big and smallport versions made available. I only want to release a product that's actually finished and doesn't require further mods. No porting the inside to get rid of the sharp edges, enlarging or adding extra barbs for vacuum, drilling the flange to suit the factory dowels in the head, grinding to suit the most common type of 4age water pipe out there or anything else that people shouldn't have to do to a brand new product.
    If everything works out here are the features these will end up with:
    - CNC milled flanges on head and for the throttles
    - 2 x CNC milled braces between the above (one of these shown in blue in the pic)
    - Molded and angled carbon fiber tubes
    - (Long enough to clear both front and rear wheel drive water pipes with the throttles the right way up) Update: no longer likely as the linkage doesn't clear
    - Curved up for more clearance off the velocity stacks
    - Enough individual ports for the following: 2 x brake booster, 4 x map and 1 x fuel reg
    - Ideal port match on both ends
    - no cheated bends or sudden changes anywhere, all with curves for max flow
    - specifically applied finish on the inside of the tubes for maximum air speed
    Even with only some of these features these manifolds would be completely superior to anything else out there and if all goes well even a lower price compared to any other product once delivered.
    In the pics below the pictured 3D model is a very early version and it's rather incomplete. In the pic the front flange is only joined #1 to #2 when later it will join all of the throttles. Also the blue brace will likely also be between #3 and #4 as well.
ID:	31919 Click image for larger version.
    If all my plans work out this may available in as soon as 4 to 8 weeks
    Estimated price: $320
    any questions?
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Awesome sounding product Sam, and a very reasonable price. I'm definitely in for one of these and your billet stacks pending final prices.
    Endeavour Hills
    Things are looking promising
    I did a test fit and without a custom throttle linkage there is no way to make these clear the RWD water pipe with the throttle the right way up. At this stage I am looking into making the option of the throttles being able to be put in either position if the holes don't overlap. I will find out. The R&D continues.
    Bryan
    Waterford
    Tramore
    Ireland
    One advantage of the upside down throttle mounting in an AE86 is a RHD AE86 accelerator cable will reach the linkage( a little tight maybe) or an AE101/111 cable which is 2" longer
    Endeavour Hills
    I tired it in the model and having the option of either direction stuffs up my vacuum port design. Oh well this is R&D for you.
    I wanted to go away from upside down throttles for this very reason, I found that with a T3 manifold the cable had 2 tight bends and there was no more throttle feel left at all, it was a stiff unresponsive pedal. Although I may have an indirect solution for this yet though.
    Bryan
    Waterford
    Tramore
    Ireland
    You could try make up a new linkage lever like the RS Chita one available for the 20Vs
    Endeavour Hills
    I could and I did think of that but that means I would have to supply that with every kit and add another $100 to it. Then I am sure many people would just see the final price more than anything else. I am facing this in other areas too for example do I include all the barbs and fittings, many won't know that they no longer need a vacuum block but they do see the manifold's price when it's $30 more, even if it is cheaper than the alternative.
    Token Member regginblack's Avatar
    reggin
    western suburbs
    Looking forward to this!!!!!
    Going to be sick!
    Dec 2013
    Jon
    Wellington
    City
    New Zealand
    Exclamation
    DIY silvertop ITB's to 16V smallport in an AE86...
    Ended up a bit close to the clutch master and brake booster, but I did manage to get an ITG sausage filter installed. Cleared everything else no worries. Making them for a bigport would be a bit more dicking around, mainly as I don't think you could just take a piece of round tube and squeeze the end.
    Cheers... axalotyl
    Endeavour Hills
    That's really neat, it sure doesn't look DIY so take that as a compliment.
    You're completely right about the issues with adapting to the bigport opening. This is the reason why I have not gone down this option. To help me understand what to do myself I would like to know why you ended up deciding to angle it upwards if you wouldn't like to share?
  1. The quad throttle onto 16V thread
    By Sam-Q in forum Technical - Questions
    Last Post: 24th January 2012, 09:15 AM
  2. carbon fiber/fiber glass hatch
    By RolandGTV85 in forum Technical - Questions
    Last Post: 12th October 2009, 09:49 PM
  3. WTB : T3 quad throttle adaptor for 16v
    By ae86hachiroku in forum Cars or Parts Wanted
    Last Post: 5th January 2009, 04:01 PM
  4. quad throttle bodies for 16v 4age
    By Jamie in forum Cars or Parts Wanted
    Last Post: 12th February 2008, 08:48 PM
