Just get some genuine trd leads. Pretty sure they are still available new. Check out greenline or nengun.
hi all, was wondering what brand leads are recommended for a bigport 4age with jdm dizzy
got top gun and eagle and both are for a ae82 so the leads are a bit short. and not as good as i had hoped
I thought discontinued but will check. Thanks
Top gun do leads for the RWD distributor also, part number is TG4464C. TG4464 is AE82 type, so make sure they order the C type. They also do the 8.8mm also (8.8SP4464C), TG4464C is just standard replacement.
I use magnacore leads on all my cars. They used to do lifetime warranty but taxi drivers were bringing them in with a million kms on them asking for warranty claims
Performance ignition will make you up a set using the plug end fittings of your existing leads
