Moved
Its not impossible but will require someone to make up a rig and then cut off the mounts from your T series and weld them on to the new diff
I am also not sure what diff centers are available for the 4runner because you will not be able to run the LSD that you have in your T series.
If you are planning to continue running an NA 4AGE I would recommend that you stick with the T series diff. It is lighter and they tend to hold up pretty well to abuse from 4AGEs.
Having said that, if you can't do doughnuts with a 4AGE your LSD may be worn out, you should be able to do doughnuts with a about 40hp if you have a good LSD...
If you want to do a swap to a bigger diff anyway here is a good article written by another American, so some of the stuff he talks about should be already reference cars available in the States, rather than what we have over here:
Current Cars:
Moved
Last edited by dove grey 64; 19th June 2014 at 08:06 PM. Reason: posted in wrong section
So I looked at what the guy did and I like what he did. He put a F series inside right! And I was wondering you know where I can buy an F series rear end the whole 7.5 because I plan on putting a 3SGTE motor in my corolla. I live in the US and can't find any ma61 at all maybe you know a site or something??
YR22 Toyota tarago had live axle F rear end.
Those are just called a toyota 'van' here in the states. Previa is also 7.5" but 5 lug.
Early toyota pickups had sone 7.5" and 8"rear ends that can be made to fit and are 4-lug. Ma47 is the supra you want. But are hard to come by.
Andrew
