what you changing to daim?
this was such a tough package
Considering selling my 4age parts.
All parts located in Launceston Tasmania
Make an offer on the parts, I have all receipts for parts and laybor.
20v silvertop head, ported, kelford 272deg 8.5mm lift cams, toda cam gears, supertech valves, valve guides, springs, titanium retainers, 1mm oversized valves, alloy rocker cover with -10 speedflow fittings, billet cas cover, 1zzfe coilpacks, cnc coilpack bracket, 800cc sard side feed injectors, billet fuel rail adaptor, rwd cooling system with cnc bypass with two tempreture sensors in rear, -8 turbo water outlet. ARP Head studs. Inc quad throttles. Cost me over $3500 in parts.
$2000ono
Wiseco 8.5.1 pistons attached to spool rods with ARP bolts. 50thou over
$500
4age oil pump and modified sump with -10 oil return, comes with baffle plate.
$150ono
4age 20v crank, has been tidied up and is in excellent condition.
$250
Sard fuel pressure reg with -6 and -8 fuel lines inc guage.
$100
Custom 20v 4age intake plenum to suit quad throttles. Cost $1100
$400ono
Intercooler and alloy piping all custom made by andrew at Radiators Plus. Inc clamps and hoses
$400ono
4agze 225mm single plate unsprung 4pk jim berry clutch and flywheel. 4 track days old. Inc fork. Cost $1150
$700
Nite parts 4a-w58 bellhousing (clutch slave on rh side). Cost $650
$500ono
W58 gearbox in excellent condition.
$700ono
W55 gearbox in excellent condition, comes with short shifter and billet stick.
$500ono
Custom 3" 1pc tailshaft from dynamic balancing. New uni etc cost $650
$450ono
Custom equal length 4age steampipe manifold, tig welded. T28 flange.
$400ono
Genuine turbosmart 38mm wastegate with gasket and bolts.
$250ono
Genuine turbosmart boost t
$50
Genuine Garrett GT3076 .63 t28/vband rear housing (duel ball bearing) in excellent condition. In restrictor, oil feed, drain and water lines all speedflow.
$1000ono
3" stainless under diff exhaust, tig welded and all manderal bent.
$350
Greddy oil cooler and relocation kit. Comes with -10 speedflow lines.
$400ono
20v silvertop chrome cam cover.
$100
Techno toy tuning water, alt and crank pulleys in red. These are the reduction type to stop cooking your alt etc.
$120ono
I probably have a lot more stuff kicking around so please feel free to pm.
This setup made 310kw and 715nm at the wheels on 28psi (gt garage dyno)
All great quality parts.
If you are after a few things I may be able to do a package.
I need to have buyers for most of this stuff before I will let them go othrrwise ill just build another bottom end.
Inspections welcome and admin please let me know if this post needs editing.
fun times.
Kind regards
Daimon 0408 358 019
---- Fryin Fifth Represent ----
this engines insane, makes me contemplate if this were in vic id consider selling my 4agte for this,
with your tailshaft is this to suit w5x + T series diff or you got something else in the rear?
haha cheers.
the diff is 8" G series 4.3
Still selling this stuff? Pretty interested in oil cooler setup and possibly gbox and bell housing?
