yeah your right, i guess i just looked at the hat height of the 33gtst rotors i got with my calipers and assumed they bolted on the back. the other thing that popped into my mind is that mx73 and ma61 boosters should bolt onto the corona firewall. i cant confirm that like i can with ra60/5 but the chassis are damn close and it gives you more possibilities when trying to source one
I have read that z32 masters are 17/16. but that is quite possibly with abs. I found out with my rona setup that the non abs r33gtst used 15/16 so went with that, also due to having 1inch in there and finding it too firm. you quite possibly will need a 1 inch master cylinder after all. If you have a decent brake shop around they should be able to set you up with a brand new master as soon as you've swaped the booster to a 4 bolt type
also another friend of mine used an mpv rotor with a modified hub and a nissan cailper no spacer or hubcentric ring needed in believe, that writeup might be on toymods somewhere too
