Results 1 to 8 of 8
Thread: sway bar bush mounts
    Default sway bar bush mounts
    just wondering if ke mounts are diff to 86.... front and back
    ive bought whitline sway bars....
    the rear bush is too small for the mount and the front bush is too big?
    do i just need to get 86 mounts
    who knows what
    Veteran biggo's Avatar
    Nick
    Noosa
    Are you talking about the d links. The metal parts? or the actuall bushes?
    yeh dlinks....
    im thinking i need 86 dlinks. but will they bolt to the keseries areas?
    Nick
    Noosa
    you wouldnt happen to have them back to front?
    i cant see the metal d links being a problem. uless you have the wrong bushes?
    Site Supporter Javal's Avatar
    Josho
    They are different KE70 to AE86.
    Quote Originally Posted by Rian View Post
    yeh dlinks....
    Riddle me this -
    Which diff and what from
    Swaybar bushes to suit what
    Swaybar to suit what
    And i can has you a solution.
    ahhh yes..
    cant have them the rong way...
    ummm ke borgy.... and 4k crossmember..
    both 86whiteline swaybars.
    Josho
    Ok, you need swaybar bushes to suit the VEHICLE application and the SWAYBAR diameter.
    I don't have my super-pro book handy. Best call your whiteline distributor. Tell them you need bushes for your KE70 to suit xx diameter swaybar.
    yehhh i assumed that first up.. but thought i may be able to get dlinks from 86 instead..
    so in future if i change the diff and or xmember... will i be using the old bushes and new dlinks?
  1. Jdm t series sway bar mounts
    By jmorley in forum Cars or Parts Wanted
    Last Post: 9th December 2011, 04:21 PM
  2. castor bush / 86 cross member / fr sway bar.
    By Evan in forum Car Parts For Sale
    Last Post: 1st June 2009, 03:21 PM
  3. rear sway bar mounts
    By lewwy in forum Technical - Questions
    Last Post: 11th August 2008, 08:45 PM
  4. sway bar mounts
    By egg_83 in forum Car Parts For Sale
    Last Post: 31st January 2008, 04:03 PM
  5. T18 sway bar mounts
    By paulie in forum Technical - Questions
    Last Post: 30th June 2006, 03:47 PM
