Results 1 to 7 of 7
Thread: AE86 20V Silvertop Engine Blueslip?
    Jan 2013
    Al
    Default AE86 20V Silvertop Engine Blueslip?
    hey all currently got a registered(NSW) 86 that had a 4ac inside, recently did the 20v ST conversion with a aftermarket microtech ecu, just curious as would it need to have an engineer certificate or just engine numbers transferred for the blue slip?
    Tried searching around but all people talked about was the 4age 16v into the 86 process.
    thanks
    Eddie
    Technically you need an eng cert but there are others that will argue that a 4a block is a 4a block. I wouldn't bank on that holding up though. NSW is pretty strict on these things. You'll have to get an engineer that will be happy with a programmable ecu as well.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I would imagine you would need it engineered and with the aftermarket ECU you're going to have a very bad time with getting it on the road legitimately. I'm sure there are ways around this however...
    Jan 2013
    Al
    yeah wish i just put in a 4age 16v would of been alot easier.
    Paul
    From a certification point of view it does not make any difference 16v vs 20v as they are both considered a performance engine with more that 20% increase in power.
    What year is the vehicle? This is going to impact on the emissions requirements for the engine change. Other than that the engine conversion is straight forward and so long as you have done it properly there should be no issues. Most engineers would want to see a JDM brake upgrade though as a minimum to deal with the extra power.
    Regards
    Paul
    Jan 2013
    Al
    Its a 1984. Ill just have to ring a few engineers in the area tomorrow.
    Eddie
    If you need an emissions test, make sure your tuner does a road tune, especially with the Microtech. I had to switch to e85 to get my emissions to pass. The Microtech has crappy tuning resolution which makes it hard to get it perfect. Make sure fuel cut on decel is fully tuned as well. It will help.
  1. WTB: 4AGE 20V Silvertop bare engine
    By silverra23 in forum Cars or Parts Wanted
    Last Post: 23rd August 2012, 12:13 PM
  2. Blacktop 20v ECU on silvertop engine
    By 99Westy in forum Technical - Questions
    Last Post: 31st August 2009, 02:11 AM
  3. Silvertop 20V engine - Now with pics
    By Svenny in forum Car Parts For Sale
    Last Post: 18th September 2008, 12:18 PM
  4. WTB: 20v SilverTop Engine Loom complete and stock ECU
    By LEVIN86 in forum Cars or Parts Wanted
    Last Post: 8th September 2008, 10:28 AM
  5. RWD 4age Silvertop 20v Race Engine + W58
    By ke25 racer in forum Car Parts For Sale
    Last Post: 12th August 2008, 08:28 AM
