Results 1 to 10 of 10
Thread: 18rg-ke70
    Senior Member 70wagon's Avatar
    Jarrad
    Barossa
    Exclamation 18rg-ke70 please help!!!!
    i have got my self a nice little 18rg which i plan on putting in my ke70. the motor came out of a ke36 pannelvan i think it is, so its got custom engine mounts and it sat perfect in the pannelvan so that the drop at the back of the sump sat right at the front of the crossmember so that the shifter sat in its normal hole but they have a different cross memeber so i need to no what to use. so if you no any thing about this please give me a yell and let me no!
    also
    my questions are
    1) is there any one here who has put one in there ke70 that could help me?
    2) dose any one no what crossmember i can use? if there is one?
    3 dose it all have to be custom stuff?
    any help on this will be appreciated
    thank you
    jarrad
    Jarrad
    Barossa
    also the tailshaft issue. ie what can i use if there is anything?
    jarrad
    Jarrad
    Barossa
    can any one help me out with this??
    Veteran shift_rook's Avatar
    SE Burbs
    k i'm going out on a limb here but because he has altered the enigne mounts to fit into the ke36 crossmember that originally housed a 4k this should bolt in to your 4k crossmember??? this is just a slightly wild guess but i thought i'd throw it out there..
    Jarrad
    Barossa
    yer i thought of that but they have a different cross member to the ke70.
    dus ne one no if i could bolt the ke36 cross member in to my ke70?
    or could i use a 3t t18 cross member coz i have one of them also.
    Site Supporter Javal's Avatar
    Josho
    Quote Originally Posted by 70wagon View Post
    You don't want to use the T18 Crossmember, as it has no provision for Rack and pinion steering, as fitted to your KE70. Unless you want to modify it of course.
    The 18R-G is a front-mid sump motor. I can't recall where the sump lies on a 4K.
    Chances are you're going to have to fabricate some engine mounts to suit your application. Unless an Ae71 crossmember is a closer fit, but i doubt it.
    Have a look where your sump lies and go from there.
    Scammer, DO NOT BUY FROM ME!
    Adam
    Sydney West
    hey man i done a 2tgeu into mine im pretty sure there nearly the same engine and mine bolted strait in with the stock 4k cross member so u should have no problem
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    that engine sat way too far foward in that van, bring it into work weel mount that junk for you.
    AE86 THE BEST
    Jarrad
    Barossa
    Quote Originally Posted by FAST EDDIE View Post
    lol that would be good but i dont have a spare million lying around tho
    but yer i dont like how far forward it sits in the panno
    Jarrad
    Barossa
    Quote Originally Posted by Javal View Post
    its a front sump motor but im hopping it would be the same process of the 2t-ke70 process coz theres lots of information on that
  1. Witzl's KE70 - 18RG Turbo for 8 valve love
    By the witzl in forum KE70 / AE71 Owners Forums
    Last Post: 17th September 2012, 10:56 AM
  2. 18rg 4-1 extractors
    By longboy in forum Car Parts For Sale
    Last Post: 21st July 2012, 04:35 PM
  3. 18rg engine package-defected ke70-xt130 lca's+ more to come
    By 70wagon in forum Car Parts For Sale
    Last Post: 1st November 2009, 05:45 PM
  4. 18rg
    By wild_70 in forum Car Parts For Sale
    Last Post: 28th March 2009, 02:44 PM
  5. Wtb: 18rg
    By millhouse in forum Cars or Parts Wanted
    Last Post: 8th March 2009, 02:00 PM
