Results 1 to 2 of 2
Thread: [WA] 1983 AE86 Toyota Sprinter Hatchback Panda 4age
    Eugene
    Default [WA] 1983 AE86 Toyota Sprinter Hatchback Panda 4age
    Australian Delivered Body, minimal rust for 31 years old, Body has done 335 thousand k, but the driveline has done a lot less due to being transplanted from a JDM car, not sure how much though.
    Car has been resprayed by the previous owner to Original Spec Panda White/Black. Was told it was Dodgy Haro's from over east a long time ago, and Harris104 had this for 6 months prior.
    Engine
    7rib oil squirters block with big port 4age (TVIS still works)
    Brand new head gasket change, with all new original Toyota gaskets ( will include leftover gaskets to new owner)
    K&N air filter
    uprated cams (was told by the previous owner, not sure what angles, but very responsive.)
    Adjustable cam pulleys
    TRD ignition leads
    Newly refurbished distributor with Viton shaft seal, new bearings and new nitrile o rings
    4.2kg lightened flywheel
    Heavy duty clutch
    4-1 tubular extractors
    Fuel surge tank hidden with BOSCH 070 EFI pump
    All new fuel hoses (Sept 2014)- Gates, parker, Mackay
    Electric fan with AE92 toyota oem temperature switch (new)
    New starter motor
    Driveline
    JDM T50 box with TRD gearset (the previous owner said this, not sure what ratio)
    JDM hydraulic master and slave cylinder with braided lines
    Custom one piece drive shaft
    Jdm rear axle with disc brakes
    kazz 2 way LSD(tight)
    New universal joint on steering,
    Suspension, brakes and wheels
    JDM front strut with JDM vented disc brakes and calipers
    Front braided brake lines
    T3 adjustable camber tops
    Lowered on AJPS springs all round
    Pedders heavy duty rear shocks (not sure whats at the front)
    Rota grids 15x8's in charcoal with near new tyres
    Interior
    Nardi Torino steering wheel (needs recovering)
    MA61 supra seats super comfortable (bracket needs some work)
    Black carpet
    Dashboard has sun damaged cracks
    Heater and fan work
    Has air con condenser not plumbed up
    Rear seats are firm
    No rust in rear tyre well
    Full size spare tyre (13” Toyota pointies)
    Exterior
    JDM mudflaps with levin logo
    Rare JDM levin flip grill
    JDM whiteline tail lights, missing centre garish
    Downside
    Diff pinion seal seeping oil around pinion bearing- needs new seal
    Passenger side spring binds a bit when turning, needs to be lubed up.
    Small dent on front driver side fender
    Slight rust in rear arches (usual places on AE86s)
    Clear coat peeling in certain areas, needs repaint to look good
    Steering has freeplay, need to adjust rack and pinion clearance since joint is new
    Needs new boss kit as the horn slide plate is just a bit too far for the horn contact
    Un-registered- due to previous owner letting registration lapse (>3 months) while working at the mines.
    I bought the car with the intent of doing it up and using it as a cool daily. I rewired the car to factory wiring -previous owner hacked the loom and relocated the engine bay relay box into the car and it was a mess. The fuel system was redone with a fuel surge tank and Bosch EFI pump hidden under the car near the fuel tank. The head gasket was changed using genuine Toyota engine seal kit (Sept 2014). All relevant seals and gasket were replaced with new genuine Toyota items. The car has fresh new oil and filter (5 Sept 2014.)
    The car runs very well and revs freely, faster than a standard bluetop (I had a few.) The LSD is working good, locks up when supposed to. Selling because I bought another AE86 that is registered.
    Comes with factory front springs, genuine Toyota gasket and seals for short block, brand new genuine Toyota windscreen top moulding ( the windscreen was changed 6 months ago).
    Price removed as it is sold
ID:	33109Click image for larger version.
ID:	33110Click image for larger version.
ID:	33111Click image for larger version.
ID:	33112Click image for larger version.
ID:	33113Click image for larger version.
ID:	33114Click image for larger version.
ID:	33115Click image for larger version.
ID:	33116Click image for larger version.
ID:	33117Click image for larger version.
ID:	33118Click image for larger version.
ID:	33119Click image for larger version.
ID:	33120Click image for larger version.
ID:	33121Click image for larger version.
ID:	33122Click image for larger version.
ID:	33123Click image for larger version.
ID:	33124Click image for larger version.
    Eugene
    20/9/2014- Deposit taken- Sold
  1. 2 x 1983 Toyota Sprinter AE86 Cars For Sale
    By Blkhrt in forum Cars for Sale (Toyota Only)
    Last Post: 30th December 2011, 01:12 PM
  2. 1983 Toyota Sprinter ae86 for sale
    By cams in forum Cars for Sale (Toyota Only)
    Last Post: 17th November 2011, 10:05 AM
  3. 1983 toyota sprinter ae86
    By schmidtyboi in forum Cars for Sale (Toyota Only)
    Last Post: 23rd August 2011, 08:31 PM
  4. [WA] AE86 Sprinter Panda Levin 4AGE
    By wartex11 in forum Cars for Sale (Toyota Only)
    Last Post: 8th August 2010, 03:45 PM
  5. Chunky Panda Spec Ae86 Toyota Sprinter
    By 1sik20valve in forum Cars for Sale (Toyota Only)
    Last Post: 13th January 2010, 02:22 AM
