Results 1 to 8 of 8
Thread: AE86 JDM Rotors on ADM calipers - Pad thickness
    May 2011
    Jonathan
    Mitchelton
    Default AE86 JDM Rotors on ADM calipers - Pad thickness
    Gday, as the title states I am using JDM Rotors on ADM Calipers.
    QFM make pads with 3mm less material to achieve this...
    but what if im stingy & currently have pads that may be worn enough to fit the JDM rotors now?
    Well the info you need is that a regular ADM pad is 14mm thick new & to fit the JDM rotors ur pads must be 11mm Thick.
    I couldnt find this info anywhere so I thought Id share.
    Happy corolla'ing
    Aug 2010
    Geoff
    mt dandenong
    Thanks for sharing, well written info like this goes a long way with future searches.
    Julian
    Northern suburbs
    Good post, quick question though do you know how much of the backing plate is taken up of this Height and how much is actual pad material?
    Rust is a way of life
    Sep 2013
    Steve
    western suburbs
    Backing plate is as per normal pads - ie 4/5mm.
    Junior Member shanny's Avatar
    May 2010
    adam
    Burgh
    i too brought slotted/vented rotors and milled down my pads to fit & worked a treat!
    Feb 2012
    Michael
    Westside
    Do you have the QFM pad code with 3mm less material? Would be interested in doing this.
    Daniel
    Ballarat
    Bump would also love to know what the pad code is please!!!
    Daniel
    Ballarat
    Finally got a set of pads here's the part number for the 3mm less pads!
  1. [QLD] Ae86 front hubs with JDM slotted rotors and calipers
    By FORDISGAY in forum Car Parts For Sale
    Last Post: 6th November 2013, 10:15 PM
  2. Replies: 7
    Last Post: 26th October 2013, 09:57 PM
  3. Brake pad clearance issue on front AE86 ADM rotors/calipers
    By Alexrex7 in forum Technical - Questions
    Last Post: 18th October 2012, 09:56 AM
  4. ADM Ae86 Brakes ( Calipers, rotors, hubs, lines.)
    By Bomfunkmc in forum Cars or Parts Wanted
    Last Post: 21st January 2012, 08:09 AM
  5. FS:slotted ADM rotors,calipers and new pads
    By ae86 drifter in forum Car Parts For Sale
    Last Post: 13th May 2007, 05:25 PM
