Man you are dedicated, good work man
Spent the afternoon ironing out problems fixed the rev lights, had no globes haha
fixed the dash illumination, after alot of fucking round measuring wires i figured out the problem was in theswitch
after alot of looking in the switch and dissasembling then reassembling many times i found the problem a crack in the
solder on the back of the terminal on the black wire and with a hit from the soldering iron was fixed!
AE86 THE BEST
Eddie gets it done again.
How do you go about ordering from Toyota Japan?
i just use my local toyota dealer, I got amayama site and part numbers from your build thread fellar!!!!
AE86 THE BEST
HAHA just you wait.......I have started buying genuine bolts now......So the engine has half the accessories bolted on with new OEM bolts.
I have a problem!
i had an epiphany today on the way to work, when i got the car there was a panhard rod rubber missing so i replaced that and have been pondering why the car is so side to side unstable then bam it hit me, the nylon bush in the panhard rod is also missing der!!!!
tomorrows plan is find a bush also replace the rh axle which is quite noisy!!!
AE86 THE BEST
Lol that'll do it!
Wheres those eyelids?
MOPAR or no car!
