Results 1 to 7 of 7
Thread: Wheels rubbing issue?
    Marchi
    Forrestdale
    Default Wheels rubbing issue?
    Ok this one is a prob ive never encountered before. The only thing that is starting to cross my mind is that i may have a bent stut or shock.
    Basically have 14" rims. not sure on width or offset. Some Watanabe look a likes. Fitted fine before. Ive put Tein coilovers on with trd inserts and camber tops. Now my tyres are scraping on the inner guards not the outter. So i cant just roll it.
    I did have full negative camber which i have wound most of it out now so there is a bit of camber. i have also tried raising it but still scrapping on 3 1/4 lock. Just wondering y ive never heard ne1 else with this problem.
    Looking on the forums people are talking about extra lock spacers and im having issues with standard lock
    Do u guys that lower ur cars and put more lock on do more mods to the inner guards of ur car. If so what?
    adjust the castor forward.. find where its hitting and get rid off the liners if their the problem.
    Veteran blair's Avatar
    Blair
    SEQ
    get better offset wheels (more -ve / less +ve)
    think about what things would contribute to it hitting there
    and its blatently obvious...
    Marchi
    Forrestdale
    The wheel is rubbing on the Seam in the arch. Can u hammer those down????
    Ive adjusted camber and ride height. Castor is as far forward as the factory can go.
    Veteran Konakid's Avatar
    Henry
    Eastern
    remove guard liners.
    bash said guard seam/lip flat against the outer guard.
    Davey & Riki-lee
    South Australia
    Seaford SA
    Get better caster rods
    Our introduction - Click here
    Ferny Grove
    yeah bash those down. rims sound to be pretty positively offsetted. longer LCA or spacers will also help
    +1 on removing plastic inner guard liners, its one of the first things you should do on a lowered 86/70/71/72
  1. Rubbing brakes. Rebuild?
    By odessy in forum Technical - Questions
    Last Post: 21st January 2012, 09:55 AM
  2. tyres rubbing
    By samuek in forum Technical - Questions
    Last Post: 1st August 2007, 06:21 PM
  3. Guard Rubbing
    By stouty in forum Technical - Questions
    Last Post: 11th June 2007, 08:39 AM
  4. Rubbing on inner guard @ full lock
    By Andor in forum Technical - Questions
    Last Post: 17th January 2007, 07:18 PM
  5. how to fix rubbing??
    By dori_86 in forum Technical - Questions
    Last Post: 29th August 2006, 09:45 PM
